| Both sides previous revision
boards:ecb:backplane-8:start [2016/02/27 13:27] admin |
boards:ecb:backplane-8:start [2024/02/10 01:00] (current) jcoffman [Hardware Documentation] |
| ====== ECB Backplane-8 167mm ====== | ====== ECB Backplane-8 167mm ====== |
| | {{:boards:ecb:backplane-8:photos:backplane8-167-assembled-1.jpg?nolink&640|}} |
| [[http://www.retrobrewcomputers.org/lib/exe/detail.php?id=boards:ecb:backplane-8:start&media=boards:ecb:backplane-8:backplane8-167-assembled-1.jpg|{{:boards:ecb:backplane-8:backplane8-167-assembled-1.jpg?640}}]] | {{:boards:ecb:backplane-8:backplane8-167-top.png?nolink&640|}} |
| [[http://www.retrobrewcomputers.org/lib/exe/detail.php?id=boards:ecb:backplane-8:start&media=boards:ecb:backplane-8:backplane8-167-bot.png|{{:boards:ecb:backplane-8:backplane8-167-bot.png?640}}]] | |
| | ===== Introduction ===== |
| The ECB Backplane-8 167 mm is a backplane card for the EuroCard Bus which allows up to 8 ECB cards to be connected at one time. | The ECB Backplane-8 167 mm is a backplane card for the EuroCard Bus which allows up to 8 ECB cards to be connected at one time. |
| {{:boards:ecb:backplane-8:backplane-201506-sch.pdf|Schematic: backplane-201506-sch.pdf}} | {{:boards:ecb:backplane-8:backplane-201506-sch.pdf|Schematic: backplane-201506-sch.pdf}} |
| Manufacturing Files: {{http://www.retrobrewcomputers.org/lib/images/smileys/fixme.gif?direct&}}Files were not on the old wiki {{http://www.retrobrewcomputers.org/lib/images/smileys/fixme.gif?nolink&}} | {{:boards:ecb:backplane-8:backplane-201506-mfg.zip|Gerbers: backplane-201506-mfg.zip}} usually 1/8" thick (heavy duty) instead of 1/16" thick |
| {{:boards:ecb:backplane-8:ecb_backplane-201506.zip|KiCAD Files: ecb_backplane-201506.zip}} | {{:boards:ecb:backplane-8:ecb_backplane-201506.zip|KiCAD Files: ecb_backplane-201506.zip}} |
| ===== John Coffman's Notes on ECB Backplane-8 ===== | |
| ==== Latest Version ==== | |
| | ===== Build Information ===== |
| | ==== John Coffman's Notes on ECB Backplane-8 ==== |
| | === Latest Version === |
| REF: ECB Backplane-201506.zip (Kicad files) | REF: ECB Backplane-201506.zip (Kicad files) |
| John Coffman 23-Jun-2015 | John Coffman 23-Jun-2015 |
| ==== Prior Version ==== | === Prior Version === |
| REF: ECB Backplane-007.zip | REF: ECB Backplane-007.zip |
| ===== Builder's Notes/Comments ===== | ===== Builder's Notes/Comments ===== |
| Please use this space to add any notes/comments on this board that don't fit into the above sections. (Periodically, these comments may be re-arranged to be better incorporated into a new revision of the wiki page.) Please sign your comments using the wiki "Insert Signature" feature! — //[[admin@retrobrewcomputers.org|Andrew Bingham]] 2016/02/27 13:01// | Please use this space to add any notes/comments on this board that don't fit into the above sections. (Periodically, these comments may be re-arranged to be better incorporated into a new revision of the wiki page.) Please sign your comments using the wiki "Insert Signature" feature! — //[[admin@retrobrewcomputers.org|Andrew Bingham]] 2016/02/27 13:01// |
| ===== Photo Gallery ===== | ===== Photo Gallery ===== |
| | {{gallery>photos?&0 }} |
| {{gallery>?&0 }} | |
| ===== File List ===== | ===== File List ===== |
| | {{filelist>*&style=table&tableheader=1&tableshowdate=1&tableshowsize=1}} |
| {{filelist>*.*&style=table&tableheader=1&tableshowdate=1&tableshowsize=1}} | |
