R03 Errata
PIO 0
PIO 1
PIO 2
PIO 3
Initial state:
  • Pin 26 (+5v) is connected to the ground plane.
  • Pin 11 (gnd) is connected to +5v via C24
End state:
  • Pin 26 (+5v) disconnected from ground plane and connected to +5v by wire link.
  • Pin 11 (gnd) connection is changed from a VCC plane to a GND plane.
Steps:
  1. Cut the thermal relief links between pin 6 and the ground plane.
  2. Link pin 6 of pio 3 to pin
boards/ecb/4pio/errata.1537075625.txt.gz · Last modified: 2018/09/16 01:27 by b1ackmai1er
