R03 Errata
Trace cuts:
  1. Cut pin 26 of IC12 (PIO-3) away from the ground plan.
  2. Cut the trace between C24 and pin 11 of IC12 (PIO-3)
  3. Cut the trace between C23 and pin 11 of IC9 (PIO-2)
  4. Cut the ground plane away from the via.
  5. Cut the ground plane to separate pin 26 of IC8 (PIO-0) and C11.
  6. Cut the trace from C11 to the via.
  7. Cut the trace between pin 11 of IC8 (PIO-0) and C8.
  8. Cut the trace between
pin 6 of IC8 (PIO-0) and pin 18 of IC4.
  1. Cut the trace between
pin 5 of IC8 (PIO-0) and pin 17 of IC4.
+5v connection:
A. Link pin 26 (IC12 PIO-3) to C12 to C9 to C11 to C8.
GND connection:
B. Link C12 to C9 to C11 to pin 11 IC8 (PIO-0) to C8.
Address selection connection:
C. Link pin 6 of IC8 (PIO-0) and pin 17 of IC4.
D. Link pin 5 of IC8 (PIO-0) and pin 18 of IC4.
boards/ecb/4pio/errata.1543226001.txt.gz · Last modified: 2018/11/26 04:53 by b1ackmai1er
