boards:ecb:4pio:errata [2018/11/26 08:12]
b1ackmai1er
boards:ecb:4pio:errata [2019/03/02 19:49] (current)
b1ackmai1er
Line 12: Line 12:
   - Cut the trace between pin 5 of IC8 (PIO-0) and pin 18 of IC4.   - Cut the trace between pin 5 of IC8 (PIO-0) and pin 18 of IC4.
   - Cut the trace between pin 6 of IC8 (PIO-0) and pin 17 of IC4.   - Cut the trace between pin 6 of IC8 (PIO-0) and pin 17 of IC4.
 +  - Cut the trace between pin 34 of IC9 (PIO-2) and pin 18 of connector P3. (Updated 3-Feb-2019)
 +5v connection: +5v connection:
Line 27: Line 28:
 D. Link pin 6 of IC8 (PIO-0) and pin 18 of IC4. D. Link pin 6 of IC8 (PIO-0) and pin 18 of IC4.
-{{https://​www.retrobrewcomputers.org/​lib/​plugins/​ckgedit/​fckeditor/​userfiles/​image/​boards/​ecb/​4pio/​errata/​errata-v2.png?​nolink&​800x968}}+{{https://​www.retrobrewcomputers.org/​lib/​plugins/​ckgedit/​fckeditor/​userfiles/​image/​boards/​ecb/​4pio/​errata/​errata-v3.png?​nolink&​800x968}}
boards/ecb/4pio/errata.1543237960.txt.gz · Last modified: 2018/11/26 08:12 by b1ackmai1er
