ECB Bus Monitor
ECB bus monitor features:
- Displays state of ECB bus address lines [A0-A15], data lines [D0-D8], and control lines using LEDs
- Allows the builder to single step through instructions
- Allows the builder to set “trap” address to halt the SBC processor when a specific address is reached
- Allows the builder to set conditional trapping combinations including on memory and I/O requests
Board:
Schematic:
Manufacturing Files:
KiCAD Files:
Default Positions of Switches
Photo Gallery
bus_monitor_parts_list_clean.pdf | 42.9 KiB | 2015/11/03 01:17 |
bus_monitor_parts_list_clean.xls | 26.5 KiB | 2015/11/03 01:17 |
busmonitor_ger.zip | 9.5 KiB | 2015/11/03 01:13 |
ecb_bus_6_english.txt | 17.8 KiB | 2015/11/03 01:09 |
ecb_bus_6_german.txt | 22.3 KiB | 2015/11/03 01:13 |
ecb_bus_monitor_default_switch_settings.txt | 856.0 B | 2015/11/03 01:09 |
ecb_bus_monitor_layout.pdf | 737.9 KiB | 2015/11/03 01:09 |
ecb_bus_monitor_schematic.pdf | 127.8 KiB | 2015/11/03 01:09 |
ecb_busmonitor-003.zip | 167.5 KiB | 2015/11/03 01:09 |
ecb_busmonitor-full-brd.pdf | 649.0 KiB | 2015/11/03 01:09 |
ecb_ct_bus_monitor.pdf | 29.5 MiB | 2015/11/03 01:09 |
ecb_led_labels.xls | 33.5 KiB | 2015/11/03 01:09 |
