ECB Bus Monitor
ECB bus monitor features:
- Displays state of ECB bus address lines [A0-A15], data lines [D0-D8], and control lines using LEDs
- Allows the builder to single step through instructions
- Allows the builder to set “trap” address to halt the SBC processor when a specific address is reached
- Allows the builder to set conditional trapping combinations including on memory and I/O requests
This board was derived from information in an article published in
Manufacturing Files:
KiCAD Files:
LED Labels
Default Positions of Switches
From: Don Caprio <ilvu...@gmail.com> Date: Sat, 02 Apr 2011 16:22:25 -0700 Local: Sat, Apr 2 2011 7:22 pm Subject: Re: [N8VEM: 9121] Re: ECB Bus Monitor Hey, I got my bus monitor working. That is lights blink, status and data LED's are responsive. Address LED's flicker during boot and running CP/M commands. This was totally a high tech approach :) I looked at the home page of the N8VEM. You see a picture of the bus monitor. If you look very closely you can pretty much tell what the position of the switches are. I set mine as pictured and it now it works. I still would like to know what the switches are and what functions they provide. Set all address switches to ON (SW_1_2 & SW_3_4). On the remaining two dip switches set them all to OFF. Turn switch position 5 ON (SW2) Turn switch position 4 and 5 ON (SW1)
Photo Gallery
bus_monitor_parts_list_clean.pdf | 42.9 KiB | 2015/11/03 01:17 |
bus_monitor_parts_list_clean.xls | 26.5 KiB | 2015/11/03 01:17 |
busmonitor_ger.zip | 9.5 KiB | 2015/11/03 01:13 |
ecb_bus_6_english.txt | 17.8 KiB | 2015/11/03 01:09 |
ecb_bus_6_german.txt | 22.3 KiB | 2015/11/03 01:13 |
ecb_bus_monitor_default_switch_settings.txt | 856.0 B | 2015/11/03 01:09 |
ecb_bus_monitor_layout.pdf | 737.9 KiB | 2015/11/03 01:09 |
ecb_bus_monitor_schematic.pdf | 127.8 KiB | 2015/11/03 01:09 |
ecb_busmonitor-003.zip | 167.5 KiB | 2015/11/03 01:09 |
ecb_busmonitor-full-brd.pdf | 649.0 KiB | 2015/11/03 01:09 |
ecb_ct_bus_monitor.pdf | 29.5 MiB | 2015/11/03 01:09 |
ecb_led_labels.xls | 33.5 KiB | 2015/11/03 01:09 |
