ECB Bus Monitor
ECB bus monitor features:
  • Displays state of ECB bus address lines [A0-A15], data lines [D0-D7], and control lines using LEDs
  • Allows the builder to single step through instructions
  • Allows the builder to set “trap” address to halt the SBC processor when a specific address is reached
  • Allows the builder to set conditional trapping combinations including on memory and I/O requests
This board was derived from information in an article published in the “c't Projekt” section of c't magazine in Germany. The original article can be found here.
Current Version: “003”
Manufacturing Files: FIXME Gerber files were not on old wiki. FIXME
KiCAD Files: ecb_busmonitor-003.zip
For information on early prototype boards, see the historical page.
LED Labels
Default Positions of Switches
Date: Sat, 02 Apr 2011 16:22:25 -0700
Local: Sat, Apr 2 2011 7:22 pm
Subject: Re: [N8VEM: 9121] Re: ECB Bus Monitor
Hey, I got my bus monitor working. That is lights blink, status and data LED's
are responsive. Address LED's flicker during boot and running CP/M commands.
This was totally a high tech approach :) I looked at the home page of the N8VEM.
You see a picture of the bus monitor. If you look very closely you can pretty much tell
what the position of the switches are. I set mine as pictured and it now it works.
I still would like to know what the switches are and what functions they provide.
Set all address switches to ON (SW_1_2 & SW_3_4).
On the remaining two dip switches set them all to OFF.
Turn switch position 5 ON  (SW2)
Turn switch position 4 and 5 ON (SW1)
bus_monitor_parts_list_clean.pdf42.9 KiB2015/11/03 01:17
bus_monitor_parts_list_clean.xls26.5 KiB2015/11/03 01:17
busmonitor_ger.zip9.5 KiB2015/11/03 01:13
ecb_bus_6_english.txt17.8 KiB2015/11/03 01:09
ecb_bus_6_german.txt22.3 KiB2015/11/03 01:13
ecb_bus_monitor_default_switch_settings.txt856.0 B2015/11/03 01:09
ecb_bus_monitor_layout.pdf737.9 KiB2015/11/03 01:09
ecb_bus_monitor_schematic.pdf127.8 KiB2015/11/03 01:09
ecb_busmonitor-003.zip167.5 KiB2015/11/03 01:09
ecb_busmonitor-full-brd.pdf649.0 KiB2015/11/03 01:09
ecb_ct_bus_monitor.pdf29.5 MiB2015/11/03 01:09
ecb_led_labels.xls33.5 KiB2015/11/03 01:09
boards/ecb/bus-monitor/start.1456602937.txt.gz · Last modified: 2016/02/27 14:55 by admin
