ECB Color Video Display Unit
  • MOS8563 display chip
  • Resistor network DAC with output on a VGA-style connector
Board: colorvdu2_board.pdf
Archived files related to prototypes & Rev 1.00 boards can be found on the retired files page
MOS8563 Documentation
BOMs
Test Programs
Builder's Notes/Comments
boards/ecb/cvdu/start.1467826581.txt.gz · Last modified: 2016/07/06 13:36 by admin
