ECB Color Video Display Unit
  • MOS8563 display chip
  • Resistor network DAC with output on a VGA-style connector
Board: colorvdu2_board.pdf
MOS8563 Documentation
BOMs
Test Programs
Builder's Notes/Comments
Note: Some photos show prototype/Rev 1.00 cards.
boards/ecb/cvdu/start.1467826802.txt.gz · Last modified: 2016/07/06 13:40 by admin
