ECB Color Video Display Unit
  • MOS8563 display chip
  • Resistor network DAC with EGA signal output on a VGA-style connector
Board: colorvdu2_board.pdf
MOS8563 Documentation
BOMs
Construction Notes
Test Programs
Color VDU Test Programs for use with Z80 CPU boards such as the SBC V2 and Mark IV.
Color VDU-188 Test Programs for use with the SBC-188.
Builder's Notes/Comments
Note: Some photos show prototype/Rev 1.00 cards.
boards/ecb/cvdu/start.1467827433.txt.gz · Last modified: 2016/07/06 13:50 by admin
