Last revision Both sides next revision
boards:ecb:mini-68k:start [2015/11/11 03:18]
admin created
boards:ecb:mini-68k:start [2016/04/30 13:08]
jcoffman [File List]
Line 1: Line 1:
-====== ECB Mini-68K Processor Card ======+====== ECB Mini-68k CPU Card ======
 +[[:boards:ecb:mfpic?media=boards:ecb:mfpic|{{:boards:ecb:mini-68k:mini68k_sm.jpg?nolink&699x404}}]]
 +===== Introduction =====
 +Current Version: 2.0-007
 +The Mini-M68K CPU board includes the following:
 +  * The MC68008 CPU board is part of a 2 board system which will require the [[:boards:ecb:mf-pic:start|MultiFunction/PIC board]]. The 8-bit version 52-pin PLCC CPU is used, not the 48-pin DIP version. The latter addresses only 1Mb whereas the former addresses 4Mb.
 +  * Memory on the CPU board itself is up to 2Mb SRAM: 4 x 512Kb chips.
 +  * ROM on the board may be Flash memory or EPROM. For development, 128Kb Flash (AMD 29F010) would be appropriate. Chip sizes up to 512Kbytes are accomodated.
 +  * Expanded memory in the form of the 4MEM board is provided for. This will allow up to 4Mb of additional paged memory.
 +  * Interrupts are vectored using the Interrupt Controller on the MF/PIC board.
 +  * The /NMI is designed to autovector. This gives a total of 9 possible interrupt sources.
 +  * The UART and timers on the MF/PIC board use 3 of these interrupts.
 +  * The ECB bus is used very much like the Z80 bus, except the address bus is expanded to 24 bits.
 +  * M68K I/O is memory mapped to the 16-bit range: $3Fxxxx. To emulate a full MC68000, during I/O operations, the address bus is driven in the range: $FFxxxx.
 +  * The memory range assignments are as follows:
 +      * $00.0000 - $1F.FFFF SRAM (on-board)
 +      * $20.0000 - $2F.FFFF 1M off-board (4MEM mapped memory)
 +      * $30.0000 - $37.FFFF optional off-board range (jumper)
 +      * $38.0000 - $3E.FFFF Flash/EPROM boot ROM
 +      * $3F.0000 - $3F.FFFF I/O space (generates /IORQ instead of /MREQ)
 +  * The CPU board uses an 8Mhz clock, and generates wait states as follows:
 +      * RAM/ROM reads: 0 w.s.
 +      * RAM writes: 0 or 1 w.s.
 +      * I/O reads: 1 or 2 w.s.
 +      * I/O writes: 2 or 3 w.s.
 +  * The board is designed to support DMA access to on-board memory. However, there are no ECB boards at this time which use this feature.
 +===== Hardware Documentation =====
 +Board: {{http://www.retrobrewcomputers.org/lib/exe/fetch.php?media=boards:ecb:mini-68k:mini-m68k-v2-pc-component.png?linkonly|mini-m68k-v2-pc-component.png}}
 +Schematic: {{:boards:ecb:mini-68k:mini-m68k-v2-sch.pdf|mini-m68k-v2-sch.pdf}}
 +Manufacturing Files: {{:boards:ecb:mini-68k:ecb_mini68k-2.0-007-mfg.zip|ecb_mini68k-2.0-007-mfg.zip}}
 +KiCad Files: {{:boards:ecb:mini-68k:ecb_minim68k-007.zip|ecb_minim68k-007.zip}}
 +===== File List =====
 +{{filelist>:boards:ecb:mini-68k:*.*&style=table&tableheader=1&tableshowdate=1&tableshowsize=1}}
 +===== BIOS ROM images: =====
 +See the [[:software:firmwareos:68000:68000|software:firmwareos:68000]] page.
boards/ecb/mini-68k/start.txt · Last modified: 2016/05/01 15:28 by jcoffman
