ECB PropIO V2
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
<directorylist: path=“./boards/ecb/propio”>
boards/ecb/propio/start.1446138041.txt.gz · Last modified: 2015/10/29 13:00 by wwarthen
