ECB PropIO V2
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
<directorylist: path=“./start/boards/ecb/propio”>
boards/ecb/propio/start.1446138107.txt.gz · Last modified: 2015/10/29 13:01 by wwarthen
