ECB PropIO V2
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
<directorylist: path=“.”>
boards/ecb/propio/start.1446138142.txt.gz · Last modified: 2015/10/29 13:02 by wwarthen
