ECB PropIO V2
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_ecb_propio_propio_v2_board_v2.00.jpg
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
boards/ecb/propio/start.1446147143.txt.gz · Last modified: 2015/10/29 15:32 by wwarthen
