ECB PropIO V2
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_ecb_propio_propio_v2_board_v2.00.jpg
[ Files | Photos ]
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
boards/ecb/propio/start.1446149961.txt.gz · Last modified: 2015/10/29 16:19 by wwarthen
