ECB PropIO V2
propio_v2_board_v2.00.jpg[ Files | Photos ]
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
boards/ecb/propio/start.1446150140.txt.gz · Last modified: 2015/10/29 16:22 by wwarthen
