ECB PropIO V2
propio_v2_board_v2.00.jpgA Propeller-based peripheral support board for the N8VEM ECB processors.
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
ecb_propio_v2.pdf955.1 KiB2017/08/25 19:48
propio2-bom.xlsx14.9 KiB2015/10/29 11:18
propio2_firmware.zip258.4 KiB2017/08/25 20:02
propio_v2.00_board.pdf292.0 KiB2015/10/29 11:18
propio_v2.00_schematic.pdf133.7 KiB2015/10/29 11:18
propio_v2.01_board.pdf297.2 KiB2015/10/29 11:18
propio_v2.01_kicad.zip226.3 KiB2015/10/29 11:18
propio_v2.01_schematic.pdf129.9 KiB2015/10/29 11:18
propio_v2.lst3.3 KiB2015/11/02 00:14
propio_v2_errata_v2.00.pdf644.0 KiB2015/10/29 11:18
Photos
propio_v2_board_v2.00.jpg1.3 MiB2015/10/29 16:17
boards/ecb/propio/start.1446351986.txt.gz · Last modified: 2015/11/01 00:26 (external edit)
