ECB PropIO V2
propio_v2_board_v2.00.jpgA Propeller-based peripheral support board for the RetroBrew Computers ECB processors.
The PropIO is a peripheral support board for the RetroBrew Computers projects based on the Parallax Propeller P8X32A MCU as an intelligent I/O controller. The Propeller MCU is ideally suited to this role as it allows for simple connection of multiple peripheral devices and utilizes a custom EEPROM based firmware that can be enhanced over time.
The PropIO V2 is intended to interface with a host processor/controller on the ECB bus such as the RetroBrew Computers SBC. The onboard EEPROM firmware of the board must be programmed with the correct firmware for the host processor/controller being used. The host software/firmware and the Propeller EEPROM firmware must act cooperatively using a prearranged protocol to communicate. At present, the pre-built PropIO V2 EEPROM firmware is intended to work with a host processor/controller running the RomWBW firmware.
  • Adds an onboard speaker
  • Adds an onboard RS-232 port
ecb_propio_v2.pdf955.1 KiB2017/08/25 19:48
propio2-bom.xlsx14.9 KiB2015/10/29 11:18
propio2_firmware.zip258.4 KiB2017/08/25 20:02
propio_v2.00_board.pdf292.0 KiB2015/10/29 11:18
propio_v2.00_schematic.pdf133.7 KiB2015/10/29 11:18
propio_v2.01_board.pdf297.2 KiB2015/10/29 11:18
propio_v2.01_kicad.zip226.3 KiB2015/10/29 11:18
propio_v2.01_schematic.pdf129.9 KiB2015/10/29 11:18
propio_v2.lst3.3 KiB2015/11/02 00:14
propio_v2_errata_v2.00.pdf644.0 KiB2015/10/29 11:18
Photos
propio_v2_board_v2.00.jpg1.3 MiB2015/10/29 16:17
Retired V1 Files
[n/a: No match]
boards/ecb/propio/start.1503707566.txt.gz · Last modified: 2017/08/25 20:32 by wwarthen
