boards:ecb:protoboard_iii:protoboard_iii [2021/03/21 01:20]
b1ackmai1er [ProtoBoard III]
boards:ecb:protoboard_iii:protoboard_iii [2021/03/21 01:28] (current)
b1ackmai1er [Version]
Line 23: Line 23:
 Gerbers are here : {{:​boards:​ecb:​protoboard_iii:​ecb_protoboard_17-10-05_mfg.zip|:​boards:​ecb:​protoboard_iii:​ecb_protoboard_17-10-05_mfg.zip}} Gerbers are here : {{:​boards:​ecb:​protoboard_iii:​ecb_protoboard_17-10-05_mfg.zip|:​boards:​ecb:​protoboard_iii:​ecb_protoboard_17-10-05_mfg.zip}}
 +Kicad file are here : {{:​boards:​ecb:​protoboard_iii:​ecb_protoboard_with_io_decode_-_17-10-05.zip|:​boards:​ecb:​protoboard_iii:​ecb_protoboard_with_io_decode_-_17-10-05.zip}}
 Please note errata for previous version [[:​boards:​ecb:​protoboard_iii:​errata|here.]] Please note errata for previous version [[:​boards:​ecb:​protoboard_iii:​errata|here.]]
-Respin consideration:​ Add +5VDC barrel jack connector, add mounting holes, ​change reset jumper to solder pad.+Respin consideration:​ Add +5VDC barrel jack connector, add mounting holes, ​add warning for installing ECB connect on ECB2.
boards/ecb/protoboard_iii/protoboard_iii.1616304016.txt.gz · Last modified: 2021/03/21 01:20 by b1ackmai1er
