EuroCard Bus Boards
ECB Backplanes
Backplane-4 An 4-slot EuroCard Bus Backplane
ECB Processor Boards
SBC-386EX Intel 80386EX processor board with 80387 coprocessor option.
ECB Input/Output/Memory Cards
VDU Monochrome 80×24 video card.
ECB Accessory Cards
"Orphaned" ECB Cards
These are ECB cards which:
Retired ECB Cards
ECB Board I/O Port Guidelines
BoardPortsFixed Port DIN 41612 b rowReset Support
ADIO N INTERRUPTSLEGACY & KONTRON
4MEM boards x 400..07 ADDRESSLEGACY
Cassette80..83N NOT USEDLEGACY & KONTRON
Disk IO V320..03, 30..3FN INTERRUPTSLEGACY & KONTRON
Dual SD card08..09 LEGACY & KONTRON
ECB USB FIFO0C..0F INTERRUPTSLEGACY & KONTRON
ECB 4PIO20..2FN NOT USEDLEGACY & KONTRON
SBC V2 on-board peripherals60..7FY NOT USEDLEGACY & KONTRON
SCG graphics (including AY-3-8910 sound)98..9FNSame as N8NOT USEDLEGACY & SOFTWARE
RAM-Floppy x 2A0..A7NBoard 1 A0-A3 Board 2 A4-A7NOT USEDLEGACY & KONTRON
Zilog peripheralsB0..BFN NOT USEDLEGACY
Prop I/OA8..AF
4UARTC0..DFN INTERRUPTS
CVDUE0..EF
VGA3E0..E7
VDU (including Keyboard, Mouse and printer port)F0..F7Y NOT USEDLEGACY
boards/ecb/start.1570154521.txt.gz · Last modified: 2019/10/03 22:02 by b1ackmai1er
