ISA XT-FDC
The XT-FDC is an 8 bit ISA board based on the National Semiconductor PC8477B floppy disk drive controller chip, a chip that supports up to four floppy disk drives. It supports up to four floppy drives internally with an optional external connector for two of those.
Hardware functionality included is:
  1. Basic FDC.
  2. Configurable IO ports, interrupts, and DMA.
  3. Optional boot ROM.
  4. Optional ROM drive. (As of May 2013: No supporting software - none currently planned).
  5. Optional connector for external floppy drive (self-powered).
  6. Optional use of a DP8473V controller chip in socket U2 instead of a PC8477B controller chip in socket U16.
  7. Optional use of an 82077AA controller chip in socket U16 instead of a PC8477B. (See 'Known Problems/Issues' section below.)
  8. Optional connector for 8“ drive (no guarantee of suitability).
This board was a project on the Vintage Computer Forum, and a large amount of useful information can be found in forum threads there. See the links in the “Build Information” section below to relevant threads on this forum.
Current Version: XT-FDC Rev 01
Board: printing_xt-fdc-brd.pdf
Schematic: printing_xt-fdc-sch.pdf
Manufacturing Files: FIXME Files were not on old wiki FIXME
KiCAD Files: isa_xt-fdc-001.zip
Note - the Vintage Computer Forums moved to a new URL in February 2016. All links below point to the new URL.
The BIOS for the XT-FDC has been written by Sergey Malinov. The latest version may be found here in case the files below are out of date. (Note that the linked page is for a different hardware board than the XT-FDC; the BIOS works with both boards).
Jumper Settings
The diagrams below document the jumper settings for the XT-FDC board. Click for larger images. Diagrams courtesy of http://www.minuszerodegrees.net/
Basic FDC:
www.minuszerodegrees.net_xtfdc_xt-fdc_20-_20jumper_20configuration_20-_20fdc_20configuration.jpg
Boot ROM:
www.minuszerodegrees.net_xtfdc_xt-fdc_20-_20jumper_20configuration_20-_20boot_20rom.jpg
ROM Drive:
www.minuszerodegrees.net_xtfdc_xt-fdc_20-_20jumper_20configuration_20-_20rom_20drive.jpg
DP8473V in socket U2:
www.minuszerodegrees.net_xtfdc_xt-fdc_20-_20jumper_20configuration_20-_20dp8473v_20in_20socket_20u2.jpg
Alternate Controller Chips
The primary intent is for a National Semiconductor PC8477B floppy disk drive controller chip to be used in socket U16. There are two other options:
  1. Intel 82077AA - in socket U16, an 82077AA is used in place of the PC8477B. Note that the -5 version of the chip (i.e. 82077AA-5) does not support 2.88M drives. At May 2013, only one tester has the 82077AA working in the XT-FDC. See the 'Known Problems/Issues' section below for more information. The use of an 82077AA has two unique requirements:
    • Capacitor C23 in place.
    • Jumper JP10 on.
  2. National Semiconductor DP8473V - nothing in socket U16, and a DP8473V in socket U2
  1. 82077AA chip - May 2013: It was anticpated that an 82077AA chip would work in socket U16. It works in modem7's second-revision prototype board, but not in the second-revision boards of nestor nor Kiwisek. For now, just be aware that there is a risk of the XT-FDC not working if an 82077AA is used.
  2. 360K Drives - Some 360K drives generate a signal on pin 34. For 360K drives that do, that will be a READY signal. A READY signal will be a problem for the XT-FDC. If you intend to connect a 360K drive to the XT-FDC that generates a signal on pin 34, then disconnect pin 34. Some drives have a jumper that can be removed to achieve that (e.g. the JU-455-7 has an 'RY' jumper). For information, that requirement is not unique to the XT-FDC board. The IBM 5162 and 5170 computers have the same requirement. Note: 1.2M drives will be expected to generate a DISK CHANGED signal on pin 34.
  3. “ROM” Errors - the following problem was fixed in version 2.2 of Sergey's BIOS:
    • On the IBM 5150 (later model), the following errors will be seen on computer power on: F660 ROM, F860 ROM, FA60 ROM, FC60 ROM
    • On the IBM 5155 and IBM 5160, the following errors will be seen on computer power on: F6600 ROM, F8600 ROM, FA600 ROM, FC600 ROM
Builder's Notes/Comments
Please use this space to add any notes/comments on this board that don't fit into the above sections. (Periodically, these comments may be re-arranged to be better incorporated into a new revision of the wiki page.) Please sign your comments using the wiki “Insert Signature” feature!
28c64.pdf660.2 KiB2016/02/28 13:37
am29f040.pdf241.2 KiB2016/02/28 13:37
dp8473.pdf354.4 KiB2016/02/28 13:37
floppy_bios-2.2.bin8.0 KiB2016/02/28 14:23
floppy_bios-2.2.tar.gz100.4 KiB2016/02/28 14:23
isa_xt-fdc-001.zip128.1 KiB2016/02/28 13:37
pc8477b.pdf573.6 KiB2016/02/28 13:37
printing_xt-fdc-brd.pdf981.6 KiB2016/02/28 13:37
printing_xt-fdc-sch.pdf277.1 KiB2016/02/28 13:37
xt-fdc-components.png86.2 KiB2016/02/28 13:39
xt-fdc.lst6.9 KiB2016/02/28 13:37
boards/isa/xt-fdc/start.txt · Last modified: 2016/02/29 06:36 by tgoodman
