www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_other_idecf2din_dsc_30871016.jpg
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_other_idecf2din_dsc_30901016.jpg
The IDE-CF daughterboard plugs into MPU302 and add additional drives to CP/M-68K as defined in the BIOS. MPUBIOS_v2 will detect the presence of the IDE-CF daughterboard automatically and assign four 8-megabyte drives, D: thru G:. Older version of MPU302 may not have the most recent BIOS, please refer to CPM BIOS Update section of MPU302 Software Updates for instruction on BIOS update.
Description
photo of board with features pointed out
operation of the board: 5V connection, 2.5mm jack required
Design Files
Part list
connector definition DIN41612 & SPI & 2nd serial
Build Log
step-by-step build process
boards/other/idecf2din/start.1511880376.txt.gz · Last modified: 2017/11/28 09:46 by plasmo
