Multicomp Cyclone II-C
Portions of the hardware and designs on this page are based on Grant Searle's original work, which was published with the following license:
cyclone_ii_c_built.jpgThe Multicomp Cyclone II-C (v1.10) is a motherboard which provides peripheral connectivity for a Cyclone II FPGA development board commonly available on eBay. The board was designed “by committee” in the retrobrewcomputers forum during December 2015, with James Moxham doing all the actual work (schematic capture and PCB layout). One of the prime motivators for this board was to fit a 10cmx10cm footprint because the manufacturing cost of PCBs of this size is particularly attractive. It provides connectivity for the following peripherals:
  • VGA Screen with PS/2 Keyboard interface
  • Two RS-232 serial ports:
    • Serial A uses on-board level-shifter and DE-9F connector or external level shifter via 6-pin connector
    • Serial B uses external level shifter via 6-pin connector
  • SD Card connector
  • Two RAM sockets to support up to 1 MB of RAM.
  • 5-pin connector for external DS1302 real-time clock and backup coin cell
  • 3V3 or 5V power option for PS/2 Keyboard, with voltage clamp diodes.
  • 3 LEDs
  • RCA Video connector
  • Jumpers for reset and for boot control
  • Debug/Expansion headers for data bus and uncommitted FPGA pins
Due to the header installation on the Cyclone II module, the module is required to be mounted inverted onto the motherboard.
The photo in this section shows a minimum build configuration using PS/2 keyboard and VGA output; no SDcard, no external RAM, and no serial ports.
Compatibility
The FPGA pin assignment for the V110 board is a superset of the pin assignment used in Grant's original design. Therefore, his original design files should work on this design with no modification. There are two caveats:
  • To use Grant's design files, the three memory links must be set correctly (see Construction (Part 2))
  • Grant's original SD controller only works with SD standard capacity cards (upto 5GBytes in size). The 6809 code presented here uses a modified design which supports both standard capacity and high-capacity (SDHC) cards.
  • The CycloneIIc-Z80 (18 Aug 2016) project below currently only works with SD standard capacity cards. To enable use with SDHC cards, copy the sd_controller.vhd file from the mc-2g-1024.zip project and overwrite the existing file in \Components\SDCARD and recompile.
QtyRefDescriptionNote
1 Cyclone II FPGA Development/Breakout Board.
1 Cyclone II V1.10 PCB
4 2 row x 14 contact 0.1“ pitch female header connector
1 VGA D15 right-angle connector (male shroud, female pin)1
3R10,12,14470R resistor1
3R11,13,15680R resistor1
1R18470R resistor2
1R191k resistor2
1 PCB-mounted RCA socket2
1 Surface-mount SD card socket
1 RTC module3
2 2-pin male header
2C3,4470uF 6V3 Electrolytic
3C12,2,100.1uF capacitor
5C9,21-240.1uF capacitor4
1 PS/2 keyboard socket1
2D1,23V6 zener diode1
2R1,210k resistor1
2R3,410k resistor7
2 32-pin 0.6” DIL IC sockets
2 1 AS6C1008 128Kx8 or (preferred) 1 or 2 AS6C4008 512Kx8
3R5,6,74K7 resistor
3LED1,2,3Red LED, 0.1“ pitch through-hole6
1 D9 right-angle connector (male shroud, female pin)4
1IC9SP3232E RS232 level shifter; 14-pin 0.3” DIL4
1 14-pin 0.3“ DIL IC socket4
- wire for jumpers5
Notes:
  1. Only if you want PS/2 keyboard and VGA output
  2. Only if you want mono TV output
  3. Only if you want a real-time clock
  4. Only if you want RS232 to 9-way D
  5. Off-cuts from resistor leads will do fine for this
  6. These are the current-limiting resistors for the LEDs. The schematic shows a value of 5K6 but that seems a bit large/makes the LEDs too dim. Your mileage may vary. Draft v1.11 board specifies 1K.
  7. Only if you are using I2C header.
Other connectors and components optional for adding external expansion connectors:
  • 6-pin 0.1” connector for Serial B external level shifter
  • 6-pin 0.1“ connector for Serial A external level shifter
  • 4-pin 0.1” connector and 2x 10K resistor for external I2C
  • 10-pin 0.1“ connector for GPIO connection
  • 8-pin 0.1” connector for Data Bus connection
You will also need:
  • Altera USB Blaster programming adaptor
  • A computer with Altera's (free) Quartus software installed
Component sourcing:
  • The FPGA board is available on http://www.ebay.com – search for ALTERA Cyclone II EP2C5T144 CPLD FPGA Development Board.
  • The PCB files are freely available so you can choose a vendor, upload the files and have a batch made. Once a couple of people have done this, there should be boards available through the forum (since few people are likely to want all 10 boards from a minimum order). I got my boards from http://www.dirtypcbs.com and they turned out well. The design is “shared” there so that anyone can order the board without the need to upload design files (You can go directly to the design at this link: http://dirtypcbs.com/store/designer/browse/9663 or you can select “PCB Store” then use your browser's page search facility to locate “Cyclone2v110”. I recommend changing the board thickness from the default of 1.2mm to 1.6mm).
  • I couldn't find 2 row x 14 contact 0.1“ headers, but I found some longer ones on ebay and cut them down with a hack-saw.
  • The surface-mount SDcard socket is for a full-size card. There are at least 2 variants with different footprints (I had to do some minor mechanical mods to get mine to fit). One suitable socket is Sparkfun part number PRT-12769
  • The VGA and PS/2 connectors ought to be source-able from an old PC motherboard. Otherwise, ebay.
  • Ebay again for the RAMs. Be sure to get 0.6” DIL parts. The AS6C4008 is only slightly more expensive than the AS6C1008. The Z80 system can make use of extra memory (paged RAM disk) and that capability is in progress for the 6809 system.
  • The SP3232 is made by Exar. The Maxim MAX3232 is an alternative. Apparently some of the MAX3232 parts on Ebay are fakes so you might want to use Farnell/CPC/RS or some other reputable source.
  • If you have no RS232 connector on your host machine you can use a serial-to-USB adaptor. Once again, ebay. Be sure to get one that can run on 3.3V power. Search for USB to serial 3.3v
  • The RTC module is available on.. ebay – search for Arduino DS1302 RTC
In all cases look at the photos here to check that the component you are choosing matches the footprint on the board.
Construction
There are various build options, as indicated in the notes of the parts list above. For now, these notes assume that you will use the PS/2 keyboard and VGA display connections. You can start by assembling the bare minimum system and go through the process of programming the FPGA board with a pre-built configuration and making sure that everything is working. Then you can go on to add the remaining components and reprogram the FPGA board. When you have assured yourself that everything is working correctly with the pre-built configurations you will have a proven stable base to go forward with either hardware or software experimentation.
Minimum Build
For a minimum build, you need only fit:
  • Decoupling capacitors (four 0.1uf and the two electrolytics). In the photo, the four 0.1uF caps for the RS232 level shifter are also fitted, but they don't need to be.
  • The PS/2 connector
  • The VGA connector
  • The 6 VGA resistors
  • The 2 PS/2 pullup resistors
  • The 2 zener diodes (see “PS/2 keyboard power” below)
  • The PS/2 power link (see “PS/2 keyboard power” below)
  • The 5V flying lead (see “PS/2 keyboard power” below)
  • The 4, 2×14 connectors for attaching the FPGA board
When fitting the 2×14 connectors, attach the FPGA board to them before soldering them into position; that will ensure that they are aligned correctly.
Have a copy of the schematic to hand while assembling the board. Because the board is so dense, some of the silk-screen references are a little hard to read. The schematic should help resolve any ambiguity.
With the minimum build completed, program the FPGA using one of the pre-built minimum configurations below.
PS/2 keyboard power
Grant's original design used 3.3V power for the PS/2 keyboard. Not all PS/2 keyboards will run at this voltage so the board provides the option of supplying either 3.3V or 5V power to the keyboard, using a wire jumper just behind the PS/2 connector.
Solder a wire jumper from the middle connection to either the 5V or the 3V connection.
The two zener diodes prevent 5V from the keyboard from over-driving the FPGA inputs. They are optional but are strongly recommended if you configure the board for 5V keyboard. With a 3V keyboard they are not needed (you can still fit them if you want; they will do no harm).
With a 5V keyboard, you also need to route 5V to the board from the FPGA board, where it is tapped off directly from the input power socket. The easiest way to do this is with a short flying lead from one of the four marked 5V pads close to the VGA connector. On the FPGA board there is a 2-pin 0.1“ connector/footprint in the corner, next to the input power socket. Use a meter to buzz out and see which pin is 5V (the other is 0V).
Theoretically, you can connect a USB keyboard using a passive USB-to-PS/2 adaptor. If anyone has done that successfully, please add a note here.
FPGA Programming
The Cyclone II FPGA is configured through internal RAM cells, and therefore its configuration is not maintained across a power cycle. The appearance of non-volatile operation is achieved by programming the configuration into a EEPROM (which is also on the FPGA breakout board) which is automatically loaded by the FPGA at power-up.
The FPGA breakout board has 2 separate 10-pin programming sockets. One is marked JTAG and is used for programming the FPGA directly (configuration endures until a power cycle). The other is marked AS (the “Active Serial” programming port) and is used for programming the EEPROM. Each connector is keyed, and the keying is rotated 180degress from one connector to the other. Programming through the JTAG port requires a .sof file. Programming through the AS port requires a .pof file. Usually, the run through Quartus will create both .sof and .pof files.
Pre-built FPGA images
Pre-built images are available for some configurations; you can use them “as-is” or as a starting point for your own modifications. See the Downloads section below.
Configuring the USB Blaster for use under Linux
The USB-Blaster works fine under Linux. The user guide tells you to create the file /etc/udev/rules.d/51-usbblaster.rules and containing the text (on a single line):
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001",MODE="0666", PROGRAM="/bin/sh -c 'K=%k; K=$${K#usbdev}; printf /proc/bus/usb/%%0
3i/%%03i $${K%%%%.*} $${K#*.}'", RUN+="/bin/chmod 0666 %c"
I found that, on my Kubuntu system, that line did not work and I used this instead:
SUBSYSTEMS=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001",MODE:="0666"
Both incantations are attempting to do the same thing: to change the protection on the USB Blaster automatically when it is plugged in.
Programming
You can program the FPGA breakout board when it is still connected to the V110 PCB. You do not need to supply power whilst programming: the programming cable provides the necessary power.
Programing is very quick; it takes about 4s.
describe in detail from within Quartus
It goes without saying (I hope..) that if you have configured the FPGA breakout board for a 6809 processor design, you can only use 6809 software. However, for the initial bring-up, everything you need is in ROM.
Bringup/debug of minimal system
The description here assumes that you have built a minimal system and programmed it with the minimal 6809 image, and that the programming completed successfully.
Connect the FPGA breakout board to the V110 PCB, and connect the 5V flying lead (if applicable). Connect the PS/2 keyboard and VGA monitor. Power-up the monitor. Connect power to the FPGA breakout board and power-up.
You should be greeted with a message in white 40-column text on the VDU:
6809 CamelForth v1.0  25 Apr 95
If not, and assuming nothing went bang investigate a little more:
  • The keyboard caps-lock LED should be illuminated. It should toggle when you press the caps-lock key repeatedly. This is implemented in hardware and has nothing to do with processor choice or code ROM.
  • The monitor should show a small flashing cursor - either after the message, or (if there's no message) in the top left-hand corner.
Here are some debug suggestions:
Effect Possible cause
kbd LED toggles OK, message on VDU Everything seems to be working fine
kbd LED toggles OK, no message on VDU, no cursor faulty monitor or cable. Bad joint on VGA connector, R10-R15 missing or faulty
kbd LED toggles OK, no message on VDU, flashing cursor processor not executing code. Should not occur with “proven” pre-built image..
no kbd LED, message on VDU Bad kbd, missing or incorrect kbd power jumper, R1-R2 missing or faulty, D1-D2 faulty or wrong orientation
no kbd LED, no message on VDU, flashing cursor Bad kbd, missing or incorrect kbd power jumper, R1-R2 missing or faulty, D1-D2 faulty or wrong orientation, processor not executing code. Should not occur with “proven” pre-built image..
no kbd LED, no message on VDU, no cursor Bad kbd, missing or incorrect kbd power jumper, R1-R2 missing or faulty, D1-D2 faulty or wrong orientation, faulty monitor or cable. Bad joint on VGA connector, R10-R15 missing or faulty, bad power supply, incorrectly programmed FPGA
Once the keyboard and VDU are working as expected, try pressing a few keys; they should be echoed on the screen. The processor is running a FORTH intepreter/compiler. I think that FORTH makes a great debug monitor. If you don't know any FORTH I suggest you spend a few minutes reading the introduction and tutorial to Gforth.
A couple of things to note about CamelForth:
  • It is case sensitive, so keep caps-lock on.
  • There is (currently) no (easy) way to save any code, so don't write anything too big.
The final piece of testing on the minimal system is to see the colour output on the VDU. Type in this program. Be careful with case (everything is in upper case except the m near the end) and with spaces:
: DIG DUP 10 / 48 + EMIT 10 MOD 48 + EMIT ;
: GR 27 EMIT ." [" DIG ." ;" DIG ." m" ;
Now try this:
44 31 GR
42 93 GR
0 30 GR
0 41 GR
0 0 GR
31 40 GR
32 40 GR
34 40 GR
47 34 GR
45 94 GR
1 34 GR
0 0 GR
1 37 GR
: GREET ." HELLO WORLD " ;
32 40 GR GREET 44 31 GR GREET
You should see coloured output on the display. Notice the two levels of intensity (visible in the white). If your output looks different, check that R10-R15 are fitted and the correct values.
Consult Grant's site for a complete list of the ANSI escape codes supported by his VDU design.
You can leave the board like this, if you want, and explore CamelForth further. Alternatively, continue with the construction; in particular, fitting an external memory.
Once you have some signs of life from the board, you can go ahead with the remainder of the construction. Fit:
  • The RAM and RAM address links (notes below)
  • The on-board RS232 (D connector, caps and socket/IC)
  • An external RS232/USB adaptor
  • The three LEDs and their current-limiting resistors
  • The SDcard socket. The footprint for this component is not standard so you might need to improvise a little.
  • The Real-time clock module. Check the pin connections on the schematic; it should wire 1-to-1 from the module down to the PCB. You can mount it on top of the RAM chip with a double-sided sticky foam pad.
  • 2-pin jumpers for RESET and VDUFFD0
  • Any other connectors you want to use either for debug or expansion
RAM selection and configuration
You can fit one or two RAM devices. If you only fit 1, it should be the device closest to the SDcard socket – three, 2-way links control the high-order addresses on that device.
To use Grant's original design (which does not drive the high-order address lines) wire all three links pin1-pin2. Otherwise, wire all three links pin2-pin3 (marked “512K” on the PCB silk-screen).
The latest Z80 and 6809 designs can access more than 64Kbytes of memory through a simple memory-mapping unit.
Bringup/debug of full system
Use the same FPGA configuration (internal RAM) to complete the testing. Connect and power-up the board as before. It should boot as before and display the CamelForth message.
Test the reset. There is a reset button on the FPGA breakout board; once you get used to where it is, you can reach around and press it even though you can't see it! Alternatively, you can fit a switch or a jumper to the “RST” pins near the LEDs. Note that the VDU logic is not reset by reset and so the screen is not cleared by reset; the processor is reset and so code execution restarts (so you will see the CamelForth message after each reset). If you use a jumper or paper-clip to short the “RST” pins you will probably see a very bouncy reset; multiple resets in quick succession.
Test the VDUFFD0 jumper. When fitted, it swaps the hardware decode of the VDU/keyboard and the SerialA port. Fit the jumper and press reset. There should be no output to the VDU. Pressing the Caps-Lock key should continue to toggle the Caps-Lock LED.
Test the Serial A RS232 port. For Serial A you can either use real RS232 by fitting a level shifter/caps/D-type or use virtual RS232 by fitting a TTL-to-USB adaptor to the 6-pin connector marked SERA. Assuming that you use RS232, use a “straight” male-to-female cable (wire 2-2, 3-3, 5-5 as a minimum) to connect to a vintage VT100.. or a terminal emulator. Configure the terminal for 115200baud, 8 data bits, 1 stop bit, no flow control. Press reset with the VDUFFD0 jumper fitted; the CamelForth message should be displayed on the monitor, and you should be able to interact with CamelForth using the terminal.
I made the mistake of fitting a male connector on my PCB, to match my female-to-female null-MoDem cable. The fix to this is to wire a female (F) connector back-to-back with a male (M) connector, wired F1-M5, F4-M3 F3-M2
Test the Serial B RS232 port. For Serial B the only connection option is to fit a TTL-to-USB adaptor to the 6-pin connector marked SERB. (Actually, I have no test procedure for this port, other than to boot NitrOS9 and type “echo hello >/T1” from the shell).
On the SERA and SERB connectors, the pins marked TX, RTS are outputs from the board, and the pins marked RX, CTS are inputs to the board. Markings on TTL-to-USB adaptors may differ, but in general you need to implement a “null-modem” in the connection, by wiring TXD from the adaptor to RXD on the board and RXD on the adaptor to TXD on the board. You definitely need the 0V connection, too. I have not connected CTS/RTS at all
Test the external memory. CamelForth uses RAM internal to the FPGA, in the address range 0x0000-0x07FF. The ROM and I/O occupy address range 0xD000-0xFFFF. All the rest of the memory space is RAM.
Run a single pass memory test like this (note PASS - singular):
HEX
1000 1FFF PASS
Or 16 (0x10) passes like this (note PASSES - plural):
HEX
1000 1FFF 10 PASSES
If this works OK, test the whole memory:
HEX
0800 CFFF 10 PASSES
Here are the definitions for the memory test routines (you don't need to type these in; they are already in ROM):
simple memory test
: STUP
start-addr end-addr -- start-addr end-addr
  2DUP SWAP DO I DUP      ! CELL +LOOP ;
: STUPI
  2DUP SWAP DO I NEGATE I ! CELL +LOOP ;
: TSTUP
  2DUP SWAP DO I DUP @      <> IF
  ."  Error@" I U. THEN CELL +LOOP ;
: TSTUPI
  2DUP SWAP DO I NEGATE I @ <> IF
: PASS STUP TSTUP STUPI TSTUPI ; ( do 1 pass)
: PASSES 0 DO ." ." PASS LOOP ;  ( do N passes)
Even if you don't know FORTH you should be able to see how definitions build on earlier (older) definitions. STUP does an incrementing memory fill where each pair of bytes contain their address (and TSTUP checks that pattern and reports errors); STUPI does an incrementing memory fill where each pair of bytes contain the 1-s complement (inverse) of their address (and TSTUPI checks that pattern and reports errors).
If the memory test fails, try reading and writing a small group of locations and try to infer what's wrong:
HEX                ( THIS IS A COMMENT - NO NEED TO TYPE IT)
1000 20 AB FILL    ( FILL FROM 1000 FOR 20 BYTES WITH VALUE AB)
1000 30 DUMP       ( DISPLAY MEMORY FROM 1000 FOR 30 BYTES)
( REPEAT THE FILL/DUMP LINES BUT REPLACE "AB" WITH THESE NUMBERS IN TURN: 0 1 2 4 8 10 20 40 80 55 AA FF)
This should allow you to see if there are any data bus problems (shorts/opens). To look for addressing problems try this:
1000 2000 STUP     ( FILL FROM 1000 TO 2000 WITH AN INCREMENTING PATTERN )
( LOOK FOR DUPLICATE VALUES IN THE DUMP. REPEAT THE DUMP, CHANGING THE RANGE. TRY USING STUPI TO FILL WITH INVERSE VALUES)
You can also use STUP and DUMP to fill/inspect memory. For example:
OK 1000 1080 STUP 1000 80 DUMP
1000  10 00 10 02 10 04 10 06  10 08 10 0A 10 0C 10 0E  ................
1010  10 10 10 12 10 14 10 16  10 18 10 1A 10 1C 10 1E  ................
1020  10 20 10 22 10 24 10 26  10 28 10 2A 10 2C 10 2E  . .".$.&.(.*.,..
1030  10 30 10 32 10 34 10 36  10 38 10 3A 10 3C 10 3E  .0.2.4.6.8.:.<.>
1040  10 40 10 42 10 44 10 46  10 48 10 4A 10 4C 10 4E  .@.B.D.F.H.J.L.N
1050  10 50 10 52 10 54 10 56  10 58 10 5A 10 5C 10 5E  .P.R.T.V.X.Z..^
1060  10 60 10 62 10 64 10 66  10 68 10 6A 10 6C 10 6E  .`.b.d.f.h.j.l.n
1070  10 70 10 72 10 74 10 76  10 78 10 7A 10 7C 10 7E  .p.r.t.v.x.z.|.~
OK 1000 1080 STUPI 1000 80 DUMP
1000  F0 00 EF FE EF FC EF FA  EF F8 EF F6 EF F4 EF F2  ................
1010  EF F0 EF EE EF EC EF EA  EF E8 EF E6 EF E4 EF E2  ................
1020  EF E0 EF DE EF DC EF DA  EF D8 EF D6 EF D4 EF D2  ................
1030  EF D0 EF CE EF CC EF CA  EF C8 EF C6 EF C4 EF C2  ................
1040  EF C0 EF BE EF BC EF BA  EF B8 EF B6 EF B4 EF B2  ................
1050  EF B0 EF AE EF AC EF AA  EF A8 EF A6 EF A4 EF A2  ................
1060  EF A0 EF 9E EF 9C EF 9A  EF 98 EF 96 EF 94 EF 92  ................
1070  EF 90 EF 8E EF 8C EF 8A  EF 88 EF 86 EF 84 EF 82  ................
OK
(typing the commands in this way will leave extra stuff on the stack, which you can ignore or clean up with ABORT. It makes the examples self-contained).
If the RAM appears to fail catastrophically, try removing it and see if you get the same behaviour. If you do, what you're seeing is just capacitance. Either the RAM is faulty or, more likely, you have set the jumpers wrongly (Ahem, I did exactly that and it took me ages to realise my mistake).
To save you trying it, I can assure you that fitting the RAM the wrong way around is a _bad_ thing to do; the board will not power up (in my case, my carelessness was not punished; the board and RAM worked correctly when I turned it around.
The most likely RAM problems are a short or open or a bent pin or bad jumpers. If you get stuck, go to to the forum and ask for help.
If you have a RAM problem, you might suspect a faulty PCB. Although this is possible, it's very unlikely. At least 12 batches of these boards have been manufactured, by multiple companies, with no apparent problems and the boards themselves are individually electrically tested.
Test the “Drive” LED. With no SDcard fitted, type this:
FLEX
LED1 should light and stay on (LED1 is the LED closest to the “RST” jumper). You need to press the reset button to recover (LED1 should go off).
Test the SDcard controller. Power-off the board and fit an SDcard (one that you don't mind corrupting). There is no card-detect mechanism so you always need to power-cycle to change the card. Type this:
HEX
200 80 DUMP
0 200 SDRD
200 80 DUMP
The 2nd line inspects the current contents of memory from 0x200-0x27F. The 3rd line loads block 0 (512 bytes in size) from the SDcard to RAM at address 0x200. The 4th line shows the final contents of memory. Assuming the SDcard is not filled with 0, you will see the memory contents change between the first and the second DUMP.
If the system hangs when you press return after the SDRD, the SDcard is not recognised or there is a connection problem.
Once everything is working, you can reprogram the FPGA with the full image - this uses the external RAM, which frees up internal RAM on the FPGA so that the VDU can be configured for 80-column operation.
If the system does not boot with the full image, go back to the minimal image and test the memory. This is really the only thing that can be causing a problem
Preparing an SDcard (6809 system)
For the 6809 system, the SDcard does not contain anything that would generally be recognised as a partition table or filesystem. Rather, it is a concatenated set of binaries and floppy disk images. To prepare the SDcard you need a tool like dd (for Linux or Mac OS). For Windows, there is a program on sourceforge called “Win32 Disk Imager” that claims to perform the equivalent task. FIXME I haven't tried it. Please update this if you have, or if you can recommend a suitable tool.
Linux Detailed Instructions
Download multicomp09_sd.img (see Downloads below) to your host computer and plug in the SDcard. Do not mount the SDcard. Use “tail /var/log/syslog” to identify the device associated with the SDcard
If you get this wrong you could corrupt your hard drive so be careful.
The device will be something like sdb (it may be reported as “sdb sdb1”). Copy the file to the device like this (change the device as appropriate)
sudo dd if=multicomp09_sd.img of=/dev/sdb
When the copy completes, remove the SDcard (it has no filesystem so you cannot “unmount” it).
Using the SDcard (6809 system)
Power off the V110 and insert the SDcard. When you power on it should boot to CamelForth as usual. The table below lists the commands used to start the different software environments that are on the SDcard image:
Command Description
BASIC Load and start Microsoft 8K BASIC. This is the image created by Grant which is used as the boot ROM on his original design.
FLEX Load and start the FLEX operating system. There are 4 virtual drives.
BUGGY Load and start Lennart Benschop's 6809 debug monitor. The killer feature of this debug monitor is its built-in line assembler/disassembler. It also has a breakpoint capability and a single-step capability (using the single-step hardware in multicomp09).
CUBIX (then type b and press return) Load and start Dave Dunfield's CUBIX operating system. There are 4 virtual drives.
NITROS9 Load and start NITROS9, an open-source re-engineered OS9. There are 4 virtual drives.
Where next?
Although there is a “canned” software download here, the latest versions and all the component parts/source code and other notes are in the multicomp6809 repository on github. There is additional documentation on the associated wiki.
A little bit more FORTH
Regardless of how much memory you have fitted, the ROMed FORTH uses RAM in the address range 0x0000-0x03FF for its workspace. Definitions that you create go into RAM from address 0x0000 upwards. There are some variables stored at the top of the RAM then a region assigned for the return stack and another region assigned for the data (parameter) stack.
Here's a simple example that allows you to see how definitions are stored in memory. Reset the system and enter these commands:
: GREET ." Hello World" ;
: HI CR GREET ;
HEX 0 80 DUMP
The dump shows how the two definitions are laid out in memory. You can see the complete list of definitions built in to CamelForth by typing WORDS:
WORDS UINIT #INIT NITROS9 FLEX BUGGY BASIC CUBIX CDTOCD EFTOCD MMUMAP PIVOTRST P
IVOT piv SDRD256n SDRD256 SDRDn SDWR SDRD SDIDLE SDLBA10 SDLBA2 PASSES PASS TSTU
PI TSTUP STUPI STUP DUMP .A .B H. .HHHH .HH .H COLD .S WORDS ENVIRONMENT? DEPTH
MOVE WITHIN POSTPONE ['] IMMEDIATE REVEAL HIDE ] [ RECURSE CREATE  ( [CHAR] CHA
R ' ABORT" ?ABORT ABORT QUIT EVALUATE INTERPRET ?NUMBER>NUMBER ?SIGN DIGIT? LIT
ERAL FIND IMMED? NFA>CFA NFA>LFA WORD>COUNTED /STRING SOURCE C, , ALLOT HERE HE
X DECIMAL . U. SIGN #> #S #>DIGIT <# HOLD UD* UD/MOD ." S" (S") TYPE ACCEPT UMA
X UMIN SPACES SPACE CR COUNT 2OVER 2SWAP 2DUP 2DROP 2! 2@ MIN MAX */ */MOD MOD /
 /MOD * FM/MOD SM/REM M* DABS ?DNEGATE DNEGATE ABS ?NEGATE S>D R0 L0 PAD S0 LP H
P LATEST 'SOURCE DP STATE BASE>IN U0 TIB TIBSIZE BL CELL  LOOP LOOP ENDLOOP LEA
VE DO L>>L REPEAT WHILE AGAIN UNTIL BEGIN ELSE THEN IF USER VARIABLE CONSTANT ;
 : DOES> (DOES>) !DEST ,DEST ,BRANCH ,EXIT !COLON ,CF !CF COMPILE,>BODY CHARS C
HAR  CELLS CELL  ALIGN ALIGNED SCAN SKIP CMOVE> CMOVE S= FILL UM/MOD UM* J I ( L
OOP) (LOOP) UNLOOP (DO) ?BRANCH BRANCH U> U<> <<> = 0<0= RSHIFT LSHIFT  ! 2/
2* 1- 1><INVERT XOR OR AND NEGATE - M    C@ @ C! ! RP! RP@ SP! SP@ R@ R>>R P
ICK TUCK NIP ROT OVER SWAP DROP ?DUP DUP EXECUTE LIT EXIT EMIT KEY? KEY
OK
(that output was wrapped at 80 columns, the width of my terminal, and may not be the latest version)
Even more FORTH
As of the June 2016 release, CamelForth includes support for block words, for loading/storing binary blobs and has (stored as part of the SDcard image) a screen-based block editor. Here is a quick getting-started guide.
The file storage uses a traditional “block” format. Each block is 1Kbyte is size and a block can hold anything you choose: txt, source code, data or binary data. There is no management of what is stored where; that is the programmer's responsibility.
The default block file contains 256 blocks (and is therefore 256KByte in size), with source code stored in the low-order block numbers. Blocks are numbered from 0 (but, you cannot load code from block 0 for various arcane historic reasons, so block zero is just use for comments)
0 LIST           ( DISPLAY BLOCK 0)
1 LIST           ( DISPLAY BLOCK 1)
1 LOAD           ( LOAD BLOCK 1.. WHICH IN TURN LOADS SOME OTHER BLOCKS)
Once the load has completed (which takes about 10s) some new capabilities are available:
WORDS            ( WORDS NOW COLOUR-CODES THE WORDS, AND HAS A BUILT-IN PAGER - PRESS SPACE FOR THE NEXT SET)
16 LIST          ( DISPLAY THE COMMANDS FOR THE SCREEN EDITOR)
1 EDIT           ( START THE SCREEN EDITOR)
                 ( ctrl-N FOR NEXT SCREEN, ctrl-P FOR PREVIOUS SCREEN)
                 ( ctrl-E TO EXIT.. LOOK AT BLOCK 16 FOR THE COMPLETE LIST)
Also, when the code was compiled it was stored back to a region of the block file in compiled form (in a format that I call a “blob”). After a reset or power-cycle you can load it back in like this:
HEX 800 ALLOT 64 RDBLOB
For more details read follow these two links:
CamelForth CamelForth save/load
Downloads
LinkFor processorUpdatedDescription
cyclone2v110.pdf anyxxDec2015PDF schematic of the V110 printed ciruit board
cyclone2v110.zip anyxxDec2015Eagle design database of V110 printed circuit board
ep2c5t144mini.pdf anyxxJul2018Leon Heller's schematic of the EP2C5T144mini FPGA board
multicomp09_sd.zip 680909Jan2016SDcard image for 6809
multicomp09_sd.zip 680911Jun2016OBSOLETE SDcard image for 6809. Updates: CamelForth utilities, single-step now works in BUGGY
multicomp09_sd.zip 680924Nov2016OBSOLETE SDcard image for 6809. Updates: Major additions to FLEX, added FUZIX
multicomp09_sd.zip 680922Apr2017SDcard image for 6809. Updates: Replaced NITROS9 Level 1 with NITROS9 Level 2.
multicomp09_iram.zip 680909Jan20166809 system with 2Kbytes of internal RAM. Works with or without external RAM. VDU runs at 40×25, colour. Use this image for debug/board bring-up
multicomp09.zip 680909Jan20166809 system with no internal RAM. Requires at least 1 external RAM. VDU runs at 80×25, colour
multicomp09.zip 680911Jun20166809 system with no internal RAM. Requires at least 1 external RAM. VDU runs at 80×25, colour. Updates: UART reset on reset. ESC key now generates 0x1b. CamelForth fixes and additions: FUZIX boot, BLOCK words, load/store pre-compiled code blobs, BLOCK Editor
multicomp09.zip 680905Nov20166809 system with no internal RAM. Requires at least 1 external RAM. VDU runs at 80×25, colour. Updates: VDU now handles line insert and delete correctly.
cycloneIIc-Z80 Z8018Aug2016Z80 System for Cyclone IIc PCB. Supports 2 serial ports, VGA, SD card and up to 1MB RAM. Default serial port speed is 9600. Mini-Monitor replaces the Multicomp monitor. Boots ROM-MJS
mc-2g-1024.zip Z8024Dec2017Z80 System for Cyclone IIc PCB (or equivalent) Provides 6 CP/M variants as well as Grant's NASCOM “ROM” Basic. Also included are 10 extra volumes with popular applications. Updates: SD card module now uses a 250 kHz SPI clock when initializing. Keyboard improvements when using built-in RCA or VGA terminal. Fix bug with setting memory disk size in 512Kb systems. Correction to install instructions. See rhkoolstar's builder page for more details
cgasanserif_multicomp_fonts.zip any24Nov2018Alternate font ROM.
Rebuilding a Quartus project from source
In general, the pre-build FPGA bundles in the downloads section do not contain everything that you need to rebuild the project in Quartus. The directory structure looks like this:
project1/
project2/
project3/
ROMS/
Components/
Where the ROMS and Components directories are common to all of the projects. The FPGA bundle will contain the files for (eg) “project1” but only a skeleton/subset of the files needed for the “ROMS” and “Components” directories.
If you want a complete tree, start by downloading the zip from Grant's site and then overlaying it with files either from the Z80 design or from the 6809 design (because the Z80 and 6809 designs have each modified some of Grant's original files, you are advised to keep independent trees of files if you are working with both)
The additional/latest 6809 files can be downloaded from github.
Images of the PCB and the layout
boards/sbc/multicomp/cycloneii-c/start.1551518746.txt.gz · Last modified: 2019/03/02 04:25 by nealcrook
