Multicomp Cyclone IV-B
Portions of the hardware and designs on this page are based on Grant Searle's original work, which was published with the following license:
cyclone_iv-b_built.jpgThe Multicomp Cyclone IV-B (v1.3) is a motherboard which provides peripheral connectivity for a Cyclone IV FPGA development board commonly available on eBay. The board was designed by James Moxham with input from Max Scane and provides connectivity for the following peripherals:
  • VGA Screen with PS/2 Keyboard interface
  • Three RS-232 serial ports with DE-9F connectors
  • Connector and serial interface for ESP8266 WiFi module
  • SD Card connector
  • Two RAM sockets to support up to 1 MB of RAM.
  • Switch mode power supply for 3.3 and 5 volt supplies
  • Dual DC Jacks for multiple power options
The Cyclone IV module is mounted onto the motherboard with easy access to the AS and JTAG connectors allowing in-place programming of the FPGA.
There is now a “Green” Cyclone IV module that has a 50 mhz oscillator and works with the CycloneIVb-50 (Green).zip (.pof file) and the CycloneIVDec2015.zip (SD card files)
Z80 Emulation Features
The Z80 VHDL code is based on Grant Searle's original Multicomp which has been extended to support the additional peripherals and the increased capacity of the Cyclone IV (EP4CE6E22C8N) chip.
The VHDL code includes the following enhanced features:
  • Memory Management Unit supporting up to 1MB of physical RAM with 16KB pages
  • Individual Baud-rate generator for each serial port
  • 20 ms interrupt generator
  • Reset of ESP8266 via RTS
  • CTS signal from serial ports
These features are supported in the ROM-MJS Enhanced Monitor
Resources
Schematic:
cycloneivjune2015.pdf44.1 KiB2015/12/28 20:23
FPGA and Eagle files
cycloneiv-b-june-2015.zip225.0 KiB2015/12/29 14:50
cycloneivb-50_green_.zip102.3 KiB2018/02/21 22:29
cycloneivb_pof.zip104.9 KiB2016/01/04 01:41
cycloneivdec2015.zip1.5 MiB2018/02/21 22:34
boards/sbc/multicomp/cycloneiv-b/start.txt · Last modified: 2018/02/21 22:36 by gkaufman
