SBC-188 version 3
The SBC-188 version 3 is an update and improvement to the earlier board. This board is better suited for 80C188 operation at 25Mhz.
- Memory size is increased to 1Mb, allowing a full DOS memory of 640K plus high memory blocks.
- The 82C55 controller is configured as a PPIDE (parallel port IDE) connection; it works with hard disks as well as CF cards.
- An IDE8 connector directly on the CPU data bus is added.
- The floppy controller and connector are present. Drives may be 360K, 1.2M, 720K, or 1.44M.
- Status LEDs indicate the sequence of boot-time P.O.S.T. diagnostics.
- The Serial I/O UART connector is altered to support RTS/CTS protocol, or crossed to DTR/DSR protocol.
- The board may be used stand-alone by powering it from the IBM 4-pin peripheral connector. In this case a terminal or terminal-emulator is attached to the serial connector.
- The board may also be inserted into any RetroBrew ECB backplane to connect to peripheral boards, including the 4MEM, DualSD, ColorVDU, VGA3, etc.
- ROMs supported may be 32Kb, 64Kb, 128Kb, or 256Kb. The current BIOS recommended is 64Kb.
- The board runs MSDOS 5.0 or MSDOS 6.22.
The Board
The bare board layout:
Finished board, ROM in raised ZIF socket for BIOS development & checkout:
sbc-188v3.1-004-sch.pdf | 491k | 22-Jan-2020 |
sbc-188v3.1-004-pcb.pdf | 1151k | 08-Jan-2020 |
sbc-188v3-board-errata.txt | 2k | 22-Jan-2020 |
sbc-188v3-gal-3.0-002.zip | 3.2K | 02-Dec-2019 |
sbc-188v3.1-004-bom.csv | 2k | 22-Jan-2020 |
sbc-188v3.1-004-bom.png | 252k | 22-Jan-2020 |
sbc-188v3.1-004-mfg.zip | 1202k | 08-Jan-2020 |
sbc-188v3.1-004.kicad.zip | 433k | 07-Feb-2020 |
dma_on_sbc-188_v3.pdf | 53k | 08-Feb-2020 |
BIOS software is here.
Version 3 of the SBC-188 is designed to support DMA access to main SRAM memory by controllers on boards on the ECB bus. Documentation for DMA access for anyone interested in creating an I/O board that uses DMA is available above. There is at this time no such ECB board; hence, the document may not be of general interest.
Board Details
The two types of Super Capacitors may be used for the RTC/NVRAM backup. Second photo shows 13.5 mm diameter cap; third photo shows a vertical mount. I used this 1.5F cap, and consider that value too large: I had to leave the board powered up overnight to get enough charge in the cap to bring the voltage above 2 volts. The good range would be 0.22F up to 0.47F. The cap in photo 2 is 0.33F.
Left photo shows the normal jumper setting for the RS-232 interface to allow RTS/CTS line protocol. The right photo shows an alternate setting which crosses RTS-CTS to DTR-DSR. This is for terminals that use the obsolete DTR/DSR line protocol. However, the programming within the UART is still RTS/CTS. If you have any doubt about which setting to use, use the one on the left.
The left photo shows a rather odd jumper (P601) labeled “INT2/INTA0”. It should always be set to “INT2” (1-2); the other setting (2-3) is for a possible future use. To the right is jumper (K601), the “Legacy/Kontron” Reset setting. In the Legacy setting (1-2) reset is put out on DIN pin C31; with the Kontron setting, DIN pin C31 is a Reset switch input to the CPU board, and the Reset signal is correctly put out on DIN pin C26 (RESOUT). All peripheral boards should also use the Kontron setting. (Kontron, a German firm, manufactured one of the earliest Zilog Z80 computers that used the 96-position DIN connector, and this was the intended pin usage.)
The right photo also shows the IBM peripheral connector, which may be used to power the board as a truly Single Board Computer, SBC-188.
Screen Images
This is a boot screen using a Wyse terminal for keyboard input and screen output:
This is the boot screen with the SBC-188 v.3 used with the VGA3 board. An IBM PC keyboard is the input device, and a VGA capable LCD monitor is used for output:
SBC-188 (original, v.2)
The SBC-188 is a Single Board Computer using the 80C188 CPU. General features include:
- CPU 80C188-16 w/512K SRAM
- UART 16c550
- ParPort 8255
- Floppy Controller WD37C65B
- ECB RetroBrew bus for expansion
This is the layout of the rev. 2.0 board: (anyone have a photo? I still run the 1.0 board)
Builder's Notes/Comments
Please use this space to add any notes/comments on this board that don't fit into the above sections. (Periodically, these comments may be re-arranged to be better incorporated into a new revision of the wiki page.) Please sign your comments using the wiki “Insert Signature” feature!
Photo Gallery
dma_on_sbc-188_v3.pdf | 52.9 KiB | 2020/02/08 13:01 |
gal-3.0-002.zip | 3.3 KiB | 2020/02/01 11:35 |
img_1353.jpg | 749.5 KiB | 2020/01/25 12:37 |
img_1356_crop.jpg | 767.9 KiB | 2020/01/25 12:37 |
img_1360.jpg | 202.6 KiB | 2020/01/26 15:10 |
img_1364.jpg | 139.6 KiB | 2020/01/26 15:10 |
img_1367.jpg | 113.9 KiB | 2020/01/26 15:10 |
img_1375.jpg | 92.7 KiB | 2020/01/26 15:10 |
img_1376.jpg | 90.3 KiB | 2020/01/26 15:10 |
img_1377.jpg | 650.6 KiB | 2020/01/25 12:37 |
img_1379.jpg | 562.3 KiB | 2020/01/25 12:41 |
img_1380.jpg | 125.2 KiB | 2020/01/25 12:41 |
img_1381.jpg | 118.8 KiB | 2020/01/25 12:41 |
img_1382.jpg | 116.9 KiB | 2020/01/26 15:10 |
sbc-188-2-007mfg.zip | 156.8 KiB | 2017/04/11 10:19 |
sbc-188-2.0-component.png | 101.2 KiB | 2017/06/21 16:05 |
sbc-188-2.0-kicad.zip | 433.4 KiB | 2017/04/11 10:19 |
sbc-188-2.0-parts_list.txt | 5.9 KiB | 2017/04/11 10:19 |
sbc-188-2.0-schematic-007.png | 669.1 KiB | 2017/04/11 10:19 |
sbc-188v3-board-errata.txt | 1.9 KiB | 2020/01/25 12:49 |
sbc-188v3.1-004-bom.csv | 2.4 KiB | 2020/01/25 12:48 |
sbc-188v3.1-004-bom.png | 246.2 KiB | 2020/01/25 12:48 |
sbc-188v3.1-004-mfg.zip | 1.2 MiB | 2020/01/25 12:49 |
sbc-188v3.1-004-pcb.pdf | 1.1 MiB | 2020/01/25 12:49 |
sbc-188v3.1-004-sch.pdf | 491.1 KiB | 2020/01/25 12:48 |
sbc-188v3.1-004.kicad.zip | 4.2 MiB | 2020/02/07 11:37 |
sbc188-vga3-boot-lg.png | 589.7 KiB | 2020/01/25 10:40 |
sbc188-xterm-boot-lg.png | 516.7 KiB | 2020/01/25 10:40 |
