boards:sbc:sbc_v2:for_beginner [2018/11/13 05:46] b1ackmai1er [1. Ordering the SBC V2 printed circuit board (pcb).] |
boards:sbc:sbc_v2:for_beginner [2018/11/13 05:54] (current) b1ackmai1er [3. Ordering the parts.] |
Line 17: | Line 17: | ||
- Next steps. | - Next steps. | ||
- | ===== start# | + | ===== 1. Ordering the SBC V2 printed circuit board (pcb). ===== |
There are two options for ordering a PCB. | There are two options for ordering a PCB. | ||
* Members of the Retrobrew Computer community offer PCBs for sale on the [[: | * Members of the Retrobrew Computer community offer PCBs for sale on the [[: | ||
- | * Manufacture your own boards using the [[:boardinventory|" | + | * Manufacture your own boards using the [[:boards: |
When you receive the pcb, it is a good idea to look over it for any obvious defects. Finding and fixing defects earlier is always better than later. One thing to look for is potential “spurs”. These are basically tiny flakes of metal that are a by-product of the manufacturing process that have accidentally fallen onto the board during construction. These look like raised areas under the green insulation layer on the pcb. If they fall on a bad spot they can short out two or more wires by connecting them together erroneously and this can cause major problems. These are generally rare, and quite hard to see, but finding one early and fixing it (by cutting it) can really pay off. | When you receive the pcb, it is a good idea to look over it for any obvious defects. Finding and fixing defects earlier is always better than later. One thing to look for is potential “spurs”. These are basically tiny flakes of metal that are a by-product of the manufacturing process that have accidentally fallen onto the board during construction. These look like raised areas under the green insulation layer on the pcb. If they fall on a bad spot they can short out two or more wires by connecting them together erroneously and this can cause major problems. These are generally rare, and quite hard to see, but finding one early and fixing it (by cutting it) can really pay off. | ||
Line 31: | Line 31: | ||
The complete parts list for the SBC V2 can be found [[: | The complete parts list for the SBC V2 can be found [[: | ||
- | The full version of the SBC V2 is designed to be connected to a Euroboard backplane so it can be using in conjunction with other boards. However, it can operate independently of the backplane and in this case not all parts are required. If you are interest in building the " | + | The full version of the SBC V2 is designed to be connected to a Euroboard backplane so it can be used in conjunction with other boards. However, it can operate independently of the backplane and in this case not all parts are required. If you are interest in building the " |
===== 3. Ordering the parts. ===== | ===== 3. Ordering the parts. ===== | ||
Line 49: | Line 50: | ||
{{filelist>: | {{filelist>: | ||
- | ===== 3. Ordering the parts. ===== | ||
- | ===== 4. Board construction and other required elements. ===== | ||
- | ===== 5. Populating the ICs (“integrated circuits” or chips). ===== | ||
- | ===== 6. Configuring the board. ===== | ||
- | ===== 7. Testing the board. ===== | ||
- | ===== 8. Next steps. ===== | ||
- | A lot of the information in these documents may be out of date: | ||
- | {{filelist>: | ||
