SBC V2-003A
  • 4Mhz+ Zilog Z80 CPU
  • Up to 512Kb paged SRAM.
  • Up to 1Mb EPROM or 512Kb FLASH ROM.
  • Serial Interface with flow control jumper options (16550 Uart)
  • Parallel interface (8255), can be extended to support IDE interface via ppi interface board.
  • Real Time Clock (DS1302)
  • Battery backup controller for RTC and SRAM (DS1210).
  • Standard ECB bus interface
  • Standard PC drive connector power supply interface using +5V only
  • Reset button with external connector
  • Bi-colour status LED.
Software Support
ROMWBW BIOS featuring:
  • CP/M / ZSDOS
  • RAM & ROM disk support.
  • Prebuild disk images.
Board
A description of the circuit operation can been seen here: http://obsolescence.wixsite.com/obsolescence/the-n8vem-sbc
A video showing the construction of the SBC-V2-003 can be seen here: https://www.youtube.com/watch?v=gXUt_EX-eo0
The current version is SBC-V2-003A.
Schematics: :boards:sbc:sbc_v2:sbc_v2-003a-sch.pdf
PCB Board: :boards:sbc:sbc_v2:sbc_v2-003a-brd.pdf
Gerbers: :boards:sbc:sbc_v2:sbc-v2-003a.zip
Kicad: :boards:sbc:sbc_v2:ecb_sbc_v2-003a-20190306.zip
Full list of parts::boards:sbc:sbc_v2:sbc-v2-parts-list.pdf
See here for minimum build and parts substitution guidelines.
Errata:
There was an error in the board layouts of sbc-v2-003 compared to the original schematic that results in the external reset not working in Kontron mode. This has been corrected in SBC-V2-003A
V2-003 schematics: :boards:sbc:sbc_v2:sbc-v2-003-sch.pdf
V2-003 board layout: :boards:sbc:sbc_v2:sbc-v2-003-brd.pdf
V2-003 Kicad files: :boards:sbc:sbc_v2:ecb_sbc_v2-003-kicad.zip
To configure the V2-003 board to work in Kontron mode with the external reset coming from the backplane the following workaround can be made.
  1. Pin 3 on K13 needs to be jumpered to Pin 2 of P6 (Reset switch jumper) - this connects the backplane reset input pin (c31) to the reset circuit input.
  2. Pin 1-2 needs to be jumpered on K13 - this connects the /reset circuit output to the backplane reset out pin(c26).
Changes from SBC V1
There is an option jumper on the Parallel Interface connector to strap pin 25 to either GND or 5v. On the V1 board this pin is tied to GND.
Jumper Settings
Board ReferenceJumper Description
Jumper setting
1-2
Jumper setting
2-3
Notes
JP1 Battery backup X
Installed - allows you to use the common battery backup on the ECB bus (pin A24).
Not installed - means either a local battery is used or no battery backup at all.
JP2One bit input portX
Installed - enables the one bit input port. This is currently
unused although could be used for external input if desired like a button or other things.
Not installed - disables the one bit input port.
K1U2 EPROM chip pins (32-pin or 28-pin)X * 32-pin EPROM used in U2 (ex. 27C080 1MBx8 EPROM) - default
X28-pin EPROM used in U2 (ex. 27C256 EPROM)
K2UART side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K3 - DTR) - default
XCTS (this should be paired with K3 - RTS)
K3UART side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K2 - DSR) - default
XRTS (this should be paired with K2 - CTS)
K4Serial side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K5 - DTR) - default
XCTS (this should be paired with K5 - RTS)
K5Serial side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K4 - DSR) - default
XRTS (this should be paired with K4 - CTS)
K6U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
X29C040 flash used in U2
K7U23 SRAM (512K or 128K)X * 512K chip used in U23 - default
X128K chip used in U23
K8U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
K9Parallel Port power control (pin 25)X * GROUND - default
XVCC ( WARNING - this setting will send VCC power down pin 25 of the parallel port which may potentially damage connected device)
K10MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
X48K upper RAM fixed/16K lower RAM switchable memory map (banked)
K11MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
K12Bus Interrupt (pin A23)X * Internal UART interrupt - default
XExternal ECB interrupt
K13ECB/Kontron Reset configurationX * ECB legacy: pin C-31 is Reset OUT to peripherals - default
X
Kontron compatible: pin C-31 is Reset IN from a SPST pushbutton pin C-26 is Reset OUT to peripherals.
N.B.: All boards in a system must use the same setting. Older boards don't have this jumper; hence, 1-2 is specified as the “default” setting. Newer systems should use the Kontron setting, since the newer backplanes have the Reset IN connector for pin C-31. (JRC 2015-7-6)
* = default setting
Modifications
A number of modifications may be made to enhance your SBC-V2-003, all of which have been incorporated in later versions.
Serial Cable Instructions
IDC-10 sideDE-9 side
24
33
52
76
95
Flow control considerations:
Your terminal should be set up for 38400, 8 bits, 1 stop bit, no line-feed after carriage return.
Teraterm is a popular terminal user program that works well with ROMWBW and the SBC V2
Status LED
A single color or bicolor LED can be installed for the status LED. The LED monitors the status of the HALT line from the Z80 CPU. Consider the color selection and orientation when choosing. A red/green LED is ideal and logically should show green when cpu is running and red when halted. Or in the case of a single colour LED, on when cpu is running and off when halted. It is wise to not fully solder in the LED until the orientation has been checked to confirm the right sequence. Or, you could install a pin header and run flying leads to an LED mounted in a case,
The HALT status can be initiated by booting CP/M and running the DDTZ debugger, loading and executing a HALT instruction.
B>ddtz
DDTZ v2.7M by CB Falconer. CPU=Z80
-a100
0100   hlt
0101
-g100
Memory Paging
The SBC can be configured with 128Kb or 512Kb RAM and up to 512Kb ROM. The Z80 processor can only access 64Kb at one time, so the additionally memory is accessed through a memory paging scheme.
The memory paging system can be configured in two different ways but the default is to be set with 32Kb of RAM fixed at the top 8000h-FFFFh memory range and for the bottom 32Kb 0000h-7FFFh being selectable from either the RAM or ROM chips. This 32Kb/32Kb configuration is what is supported by the ROMWBW software package.
Under the 32Kb/32Kb configuration, the top 32Kb is mapped to the last 32Kb of the 128Kb or 512Kb RAM chip and the lower 32Kb is selected from RAM or ROM by writing the required address line configuration to the RAM or ROM memory page configuration latch.
Port Map
The SBC V2 uses address 60h - 7Fh for on board peripherals. Address decoding is not complete so some address ports are duplicated within this address range. All other I/O address ranges are exported to the ECB.
PeripheralFunctionAddress
82C55 PPIParallel Port60h-63h ( & 64h-67h)
16550 UARTSerial Port68h-6Fh
DS1302 RTCReal Time Clock70h ( & 71h-77h)
RAMRAM bank select latch (Write Only)78h ( & 79h)
ROMROM bank select latch (Write Only)7Ch ( & 7Eh)
One Bit Input Port
SBC_std_cust.asm
CRTACT        .SET    TRUE           ; CRT ACTIVATION AT STARTUP
VDAEMU        .SET    EMUTYP_ANSI    ; DEFAULT VDA EMULATION (EMUTYP_TTY, EMUTYP_ANSI, ...)
REAL TIME CLOCK (RTC)
Loading CPM...
CP/M-80 Version 2.2C for the N8VEM, October 2008
Run XM from A drive, this downloads file to B drive
A>rtc
Start RTC Program
RTC: Version 1.0
RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp
RTC: trickle charger disabled.
RTC>
Benchmark
asciiart.bas benchmark for SBC-V2 8Mhz Z80 board running Microsoft MBASIC v5.21:
2m32s
10 FOR Y=-12 TO 12
20 FOR X=-39 TO 39
30 CA=X*.0458
40 CB= Y*.08333
50 A=CA
60 B=CB
70 FOR I=0 TO 15
80 T=A*A-B*B+CA
90 B=2*A*B+CB
100 A=T
110 IF (A*A+B*B)>4 THEN GOTO 200
120 NEXT I
130 PRINT " ";
140 GOTO 210
200 IF I>9 THEN I=I+7
205 PRINT CHR$(48+I);
210 NEXT X
220 PRINT
230 NEXT Y
000000011111111111111111122222233347E7AB322222111100000000000000000000000000000
000001111111111111111122222222333557BF75433222211111000000000000000000000000000
000111111111111111112222222233445C      643332222111110000000000000000000000000
011111111111111111222222233444556C      654433332211111100000000000000000000000
11111111111111112222233346 D978 BCF    DF9 6556F4221111110000000000000000000000
111111111111122223333334469                 D   6322111111000000000000000000000
1111111111222333333334457DB                    85332111111100000000000000000000
11111122234B744444455556A                      96532211111110000000000000000000
122222233347BAA7AB776679                         A32211111110000000000000000000
2222233334567        9A                         A532221111111000000000000000000
222333346679                                    9432221111111000000000000000000
234445568  F                                   B5432221111111000000000000000000
                                              864332221111111000000000000000000
boards/sbc/sbc_v2/sbc_v2-003.txt · Last modified: 2020/12/01 05:46 by b1ackmai1er
