SBC V2
  • 4Mhz Zilog Z80 CPU
  • Up to 512Kb paged SRAM.
  • Up to 1Mb EPROM or FLASH ROM.
  • Serial Interface (16550 Uart)
  • Parallel interface (8255), can be extended to support IDE interface via small board
  • Real Time Clock (DS1302)
  • Battery backup for RTC and SRAM.
  • Standard ECB bus interface
  • Standard PC drive connector power supply interface using +5V only
  • Reset button with external connector
  • Status LED
Software Support
  • ROMWBW BIOS featuring
    • CP/M / ZSDOS
    • RAM & ROM disk support.
Board
A description of the circuit operation can been seen here: http://obsolescence.wixsite.com/obsolescence/the-n8vem-sbc
A video showing the construction of the SBC-V2-003 can be seen here: https://www.youtube.com/watch?v=gXUt_EX-eo0
The current version is SBC-V2-003A. A new version is under development and details can be found here.
Schematics: :boards:sbc:sbc_v2:sbc_v2-003a-sch.pdf
PCB Board: :boards:sbc:sbc_v2:sbc_v2-003a-brd.pdf
Gerbers: :boards:sbc:sbc_v2:sbc-v2-003a.zip
Kicad: :boards:sbc:sbc_v2:ecb_sbc_v2-003a-20190306.zip
Jumper Settings
Board ReferenceJumper Description
Jumper setting
1-2
Jumper setting
2-3
Notes
JP1 Battery backup X
Installed - allows you to use the common battery backup on the ECB bus (pin A24).
Not installed - means either a local battery is used or no battery backup at all.
JP2One bit input portX
Installed - enables the one bit input port. This is currently
unused although could be used for external input if desired like a button or other things.
Not installed - disables the one bit input port.
K1U2 EPROM chip pins (32-pin or 28-pin)X * 32-pin EPROM used in U2 (ex. 27C080 1MBx8 EPROM) - default
X28-pin EPROM used in U2 (ex. 27C256 EPROM)
K2UART side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K3 - DTR) - default
XCTS (this should be paired with K3 - RTS)
K3UART side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K2 - DSR) - default
XRTS (this should be paired with K2 - CTS)
K4Serial side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K5 - DTR) - default
XCTS (this should be paired with K5 - RTS)
K5Serial side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K4 - DSR) - default
XRTS (this should be paired with K4 - CTS)
K6U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
X29C040 flash used in U2
K7U23 SRAM (512K or 128K)X * 512K chip used in U23 - default
X128K chip used in U23
K8U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
K9Parallel Port power control (pin 25)X * GROUND - default
XVCC ( WARNING - this setting will send VCC power down pin 25 of the parallel port which may potentially damage connected device)
K10MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
X48K upper RAM fixed/16K lower RAM switchable memory map (banked)
K11MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
K12Bus Interrupt (pin A23)X * Internal UART interrupt - default
XExternal ECB interrupt
K13ECB/Kontron Reset configurationX * ECB legacy: pin C-31 is Reset OUT to peripherals - default
X
Kontron compatible: pin C-31 is Reset IN from a SPST pushbutton pin C-26 is Reset OUT to peripherals.
N.B.: All boards in a system must use the same setting. Older boards don't have this jumper; hence, 1-2 is specified as the “default” setting. Newer systems should use the Kontron setting, since the newer backplanes have the Reset IN connector for pin C-31. (JRC 2015-7-6)
* = default setting
Serial Cable Instructions
IDC-10 sideDE-9 side
24
33
52
76
95
Flow control considerations:
In the absence of flow control, guidelines for baud rate settings are:
4Mhz CPU Crystal - 38400 baud
8Mhz CPU Crystal - 57600 baud
Full list of parts::boards:sbc:sbc_v2:sbc-v2-parts-list.pdf
See here for minimum build and parts substitution guidelines.
REAL TIME CLOCK (RTC)
Loading CPM...
CP/M-80 Version 2.2C for the N8VEM, October 2008
Run XM from A drive, this downloads file to B drive
A>rtc
Start RTC Program
RTC: Version 1.0
RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp
RTC: trickle charger disabled.
RTC>
RTC.COM is part of Wayne Warthen's ROMWBW package.
Status LED
A single color or bicolor LED can be installed for the status LED. The LED monitors the status of the HALT line from the Z80 CPU. Consider the color selection and orientation when choosing. A red/green LED is ideal and logically should show green when cpu is running and red when halted. Or in the case of a single colour LED, on when cpu is running and off when halted. It is wise to not fully solder in the LED until the orientation has been checked to confirm the right sequence. Or, you could install a pin header and run flying leads to an LED mounted in a case,
The HALT status can be initiated by booting CP/M and running the DDTZ debugger, loading and executing a HALT instruction.
B>ddtz
DDTZ v2.7M by CB Falconer. CPU=Z80
-a100
0100   hlt
0101
-g100
Memory Paging
The SBC can be configured with 128Kb or 512Kb RAM and up to 512Kb ROM. The Z80 processor can only access 64Kb at one time, so the additionally memory is accessed through a memory paging scheme.
The memory paging system can be configured in two different ways but the default is to be set with 32Kb of RAM fixed at the top 8000h-FFFFh memory range and for the bottom 32Kb 0000h-7FFFh being selectable from either the RAM or ROM chips. This 32Kb/32Kb configuration is what is supported by the ROMWBW software package.
Under the 32Kb/32Kb configuration, the top 32Kb is mapped to the last 32Kb of the 128Kb or 512Kb RAM chip and the lower 32Kb is selected from RAM or ROM by writing the required address line configuration to the RAM or ROM memory page configuration latch.
One Bit Input Port
SBC_std_cust.asm
CRTACT        .SET    TRUE           ; CRT ACTIVATION AT STARTUP
VDAEMU        .SET    EMUTYP_ANSI    ; DEFAULT VDA EMULATION (EMUTYP_TTY, EMUTYP_ANSI, ...)
Boot "BEEP" modification
There is no inbuilt sound on the SBC V2-003 board. Complex sound output can be achieved with the ECB-SCG (Sprite-Colour-Graphics) board.
Rudimentary sound support can be add the SBC V2 by utilizing one of the unused outputs of the RTC interfacing latch and connecting a simple amplifier to this output.
On U18 74LS174 connect a ground wire from pin 8 and a signal wire from pin 2 to an amplifier. Generic LM386 amplifiers are available from many sources and work well.
With this addition and the SPKENABLE setting set to TRUE in ROMWBW, the SBC V2 will issue a beep sound on bootup.
A transistor speaker driver has been incorporated in the SBC-V2-004 so a speaker can be connected directly to the board.
Sound support has been added to NASCOM BASIC in ROMWBW 2.9.2-pre.17:
PLAY O,N,D
Where:
 O = OCTAVE 0-8
 N = NOTE 0-11
 D = DURATION 1-8 (8ths of a second)
Example:
 Middle C for one second = PLAY 4,0,8
Speed switch modification:
The following modification allows the cpu clock speed to be changed from full to half speed under program control. The purpose of this modification is to provide a level of compatibility with MSX applications while retaining the high speed capability. Specifically a 7.159Mhz crystal can be installed for normal operation including high density floppy disk support but be switched to 3.5795Mhz to drive the Sprite Colour Graphics board when required.
This modification requires a 74LS74 to be modified and mounted on top of U4. Five leads are required to connect to other parts of the circuit. Suggested installation method:
Prepare connection points for new clock source:
  1. Remove Z80 CPU U4 and fold out pin 6 and reinsert.
  2. Remove 74LS244 U17 and fold out pin 6 and reinsert.
Prepare a 74LS74 for mounting on 74LS10 U4
  1. Fold up pins 1-6 and 8-13 and snip off the ends leaving the stubs. Pin 7 and 14 remain for connecting to 74LS10 U4.
  2. Solder a wire from pin 14 to pin 1 and then to pin 11 (brown wire).
  3. Solder a wire from pin 4 to pin 9 (blue wire)
  4. Solder wire from pin 13 to pin 5 (green wire)
  5. Solder wire from pin 12 to pin 7 (yellow wire)
Mounting 74LS74 and connecting flying leads on component side of board:
  1. Place the 74LS74 over 74LS10 U4 so only pin 7 and 14 are touching.
  2. Solder pin 14's together and pin 7's together.
  3. Solder a wire from pin 2 of the 74LS74 to pin 5 of 74LS174 U18 (purple wire)
  4. Solder a wire from pin 11 of the 74LS74 to pin 12 of 74LS06 U26 (orange wire)
  5. Solder a wire from pin 3 of 74LS74 to pin 13 74LS06 U26 (red wire).
  6. Solder a wire from 7 of the 74LS74 to lifted pin 6 of 74LS244 U17 and then to lifted pin 6 of Z80 CPU U24 (yellow wire)
Solder side connections:
  1. Solder wire from pin 5 of CPU clock P4 to pin 13 74LS06 U26 (red wire).
Software control
Bit 4 of port 70h is used to select the clock speed. The normal condition is for Bit 4 to be set to 0 (low) and this will select the full clock speed of the installed crystal. Writing a 1 (high) to Bit 4 of port 70h will activate the 74LS74 clock divider. The speed switch is currently not supported in ROMWBW. Use of the RTC or speaker will reset Bit 4 to 0 i.e. full speed operation. Further, precalculated software delays or delays based on the initial speed detected at boot time do not take into account the possibility of the speed changing.
Demonstration code:
1 OUT 112,0
2 PRINT "NORMAL SPEED"
3 GOSUB 10
4 OUT 112,8
5 PRINT "SLOW SPEED"
6 GOSUB 10
7 END
10 FOR X=1 TO 64
20 PRINT ".";
30 FOR Y=1 TO 256
40 NEXT Y
50 NEXT X
60 PRINT
70 RETURN
Demonstration video
Recovery mode switch modification:
In some situations, reflashing a new ROMWBW image may result in an inaccessible system. This may happen when conflicts occur due to enabling additional ROMWBW features, when additional drivers are selected or during development.
A basic recovery mode process can be activated, so that the minimum driver set is activated on boot. This is achieved by activating the BT_REC_TYPE option in your custom configuration. When activated ROMWBW will check an input at boot time to see if the recovery mode should be activated. A number of options can be selected to define what this input is.
Example:
SBC_std_cust.asm
BT_REC_TYPE    .SET    BT_REC_SBC1B    ; CHECK 1-BIT IO PORT
Boot recover input options:
BT_REC_NONE      NO RECOVERY MODE
BT_REC_FORCE     FORCE BOOT RECOVERY MODE
BT_REC_SBC01     BIT 1 RTC HIGH
BT_REC_SBC1B     1-BIT IO PORT
BT_REC_SBCRI     16550 UART RING INDICATOR LINE
BT_REC+SBC1B utilized the existing 1-BIT IO jumper header on the SBC-V2. Connecting a push buttons switch to this header is all that is required. However, this will override the CRTACT option if that is in use. The following two options use other inputs that do not interfere with existing setting but require modification to the board
BT_REC_SBC01 uses the RTC data line and requires soldering a push button switch to GND and RTC clock data line.
BT_REC_SBCRI used the unused 16550 UART Ring Indicator line as an input. A more complex modification required. The ring indicator pin needs to be lifted out of the socket and a resistor and push button switch wired in.
Port Map
The SBC V2 uses address 60h - 7Fh for on board peripherals. Address decoding is not complete so some address ports are duplicated within this address range. All other I/O address ranges are exported to the ECB.
PeripheralFunctionAddress
82C55 PPIParallel Port60h-63h ( & 64h-67h)
16550 UARTSerial Port68h-6Fh
DS1302 RTCReal Time Clock70h ( & 71h-77h)
RAMRAM bank select latch (Write Only)78h ( & 79h)
ROMROM bank select latch (Write Only)7Ch ( & 7Eh)
Benchmark
asciiart.bas benchmark for SBC-V2 8Mhz Z80 board running Microsoft MBASIC v5.21:
2m32s
10 FOR Y=-12 TO 12
20 FOR X=-39 TO 39
30 CA=X*.0458
40 CB= Y*.08333
50 A=CA
60 B=CB
70 FOR I=0 TO 15
80 T=A*A-B*B+CA
90 B=2*A*B+CB
100 A=T
110 IF (A*A+B*B)>4 THEN GOTO 200
120 NEXT I
130 PRINT " ";
140 GOTO 210
200 IF I>9 THEN I=I+7
205 PRINT CHR$(48+I);
210 NEXT X
220 PRINT
230 NEXT Y
000000011111111111111111122222233347E7AB322222111100000000000000000000000000000
000001111111111111111122222222333557BF75433222211111000000000000000000000000000
000111111111111111112222222233445C      643332222111110000000000000000000000000
011111111111111111222222233444556C      654433332211111100000000000000000000000
11111111111111112222233346 D978 BCF    DF9 6556F4221111110000000000000000000000
111111111111122223333334469                 D   6322111111000000000000000000000
1111111111222333333334457DB                    85332111111100000000000000000000
11111122234B744444455556A                      96532211111110000000000000000000
122222233347BAA7AB776679                         A32211111110000000000000000000
2222233334567        9A                         A532221111111000000000000000000
222333346679                                    9432221111111000000000000000000
234445568  F                                   B5432221111111000000000000000000
                                              864332221111111000000000000000000
Changes and Errata:
Information regarding V1 can be found here.
Information regarding V2 can be found here.
boards/sbc/sbc_v2/start.txt · Last modified: 2020/01/28 07:05 by b1ackmai1er
