SBC V2
Previously known as the N8VEM SBC, development began in 2006 wth V1 and is currently still in development.
For most people, the SBC-V2-004 offers the most convenience and functionality.
- 4Mhz+ Zilog Z80 CPU.
- Up to 512Kb paged SRAM.
- Up to 1Mb EPROM or 512Kb Flash ROM.
- Serial Interface.
- IDE interface.
- Real Time Clock.
- Onboard sound.
- Battery backup for RTC and SRAM via super capacitor.
- Standard ECB bus interface.
- +5V power connector for Single Board Computer operation.
- Reset button.
- Status LED.
Software Support
ROMWBW BIOS featuring:
- CP/M / ZSDOS
- RAM & ROM disk support.
- ROM based BASIC, FORTH and Monitor.
- Prebuild disk images
Version History
Version | Details | Key feature |
SBC V1 | Initial version | Runs as Single Board Computer or on Euro Card Bus. |
SBC V2-003 | Enhanced version | Battery backed RAM support, Serial jumper options, RAM and ROM configuration options. |
SBC V2-004 | Extended version | IDE connector, sound, Clock speed control, Super capacitor for RAM and RTC backup. |
SBC V2-005 | In development | 1Mb Flash support. |
Jumper Settings
Board Reference | Jumper Description | Jumper setting 1-2 | Jumper setting 2-3 | Notes |
JP1 | Battery backup | X | Installed - allows you to use the common battery backup on the ECB bus (pin A24). Not installed - means either a local battery is used or no battery backup at all. |
JP2 | One bit input port | X | Installed - enables the one bit input port. This is currently unused although could be used for external input if desired like a button or other things. Not installed - disables the one bit input port. |
K1 | U2 EPROM chip pins (32-pin or 28-pin) | X * | 32-pin EPROM used in U2 (ex. 27C080 1MBx8 EPROM) - default | |
X | 28-pin EPROM used in U2 (ex. 27C256 EPROM) | |||
K2 | UART side hardware handshaking (DSR, CTS) | X * | DSR (this should be paired with K3 - DTR) - default | |
X | CTS (this should be paired with K3 - RTS) | |||
K3 | UART side hardware handshaking (DTR, RTS) | X * | DTR (this should be paired with K2 - DSR) - default | |
X | RTS (this should be paired with K2 - CTS) | |||
K4 | Serial side hardware handshaking (DSR, CTS) | X * | DSR (this should be paired with K5 - DTR) - default | |
X | CTS (this should be paired with K5 - RTS) | |||
K5 | Serial side hardware handshaking (DTR, RTS) | X * | DTR (this should be paired with K4 - DSR) - default | |
X | RTS (this should be paired with K4 - CTS) | |||
K6 | U2 chip type (27C080 EPROM, 29C040 flash) | X * | 27C080 EPROM used in U2 - default | |
X | 29C040 flash used in U2 | |||
K7 | U23 SRAM (512K or 128K) | X * | 512K chip used in U23 - default | |
X | 128K chip used in U23 | |||
K8 | U2 chip type (27C080 EPROM, 29C040 flash) | X * | 27C080 EPROM used in U2 - default | |
K9 | Parallel Port power control (pin 25) | X * | GROUND - default | |
X | VCC ( WARNING - this setting will send VCC power down pin 25 of the parallel port which may potentially damage connected device) | |||
K10 | MCPL (Memory Page Config Latched) | X * | 32K upper RAM fixed/32K lower RAM switchable memory map - default | |
X | 48K upper RAM fixed/16K lower RAM switchable memory map (banked) | |||
K11 | MCPL (Memory Page Config Latched) | X * | 32K upper RAM fixed/32K lower RAM switchable memory map - default | |
K12 | Bus Interrupt (pin A23) | X * | Internal UART interrupt - default | |
X | External ECB interrupt | |||
K13 | ECB/Kontron Reset configuration | X * | ECB legacy: pin C-31 is Reset OUT to peripherals - default | |
X | Kontron compatible: pin C-31 is Reset IN from a SPST pushbutton pin C-26 is Reset OUT to peripherals. N.B.: All boards in a system must use the same setting. Older boards don't have this jumper; hence, 1-2 is specified as the “default” setting. Newer systems should use the Kontron setting, since the newer backplanes have the Reset IN connector for pin C-31. (JRC 2015-7-6) |
* = default setting
Serial Cable Instructions
IDC-10 side | DE-9 side |
2 | 4 |
3 | 3 |
5 | 2 |
7 | 6 |
9 | 5 |
Flow control considerations:
In the absence of flow control, guidelines for baud rate settings are:
4Mhz CPU Crystal - 38400 baud
8Mhz CPU Crystal - 57600 baud
REAL TIME CLOCK (RTC)
Loading CPM... CP/M-80 Version 2.2C for the N8VEM, October 2008 Run XM from A drive, this downloads file to B drive A>rtc Start RTC Program RTC: Version 1.0 RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp RTC: trickle charger disabled. RTC>
One Bit Input Port
SBC_std_cust.asm
CRTACT .SET TRUE ; CRT ACTIVATION AT STARTUP VDAEMU .SET EMUTYP_ANSI ; DEFAULT VDA EMULATION (EMUTYP_TTY, EMUTYP_ANSI, ...)
Boot "BEEP" modification
There is no inbuilt sound on the SBC V2-003 board. Complex sound output can be achieved with the ECB-SCG (Sprite-Colour-Graphics) board.
Rudimentary sound support can be add the SBC V2 by utilizing one of the unused outputs of the RTC interfacing latch and connecting a simple amplifier to this output.
On U18 74LS174 connect a ground wire from pin 8 and a signal wire from pin 2 to an amplifier. Generic LM386 amplifiers are available from many sources and work well.
With this addition and the SPKENABLE
setting set to TRUE
in ROMWBW, the SBC V2 will issue a beep sound on bootup.
A transistor speaker driver has been incorporated in the SBC-V2-004 so a speaker can be connected directly to the board.
Sound support has been added to NASCOM BASIC in ROMWBW 2.9.2-pre.17:
PLAY O,N,D Where: O = OCTAVE 0-8 N = NOTE 0-11 D = DURATION 1-8 (8ths of a second) Example: Middle C for one second = PLAY 4,0,8
Speed switch modification:
The following modification allows the cpu clock speed to be changed from full to half speed under program control. The purpose of this modification is to provide a level of compatibility with MSX applications while retaining the high speed capability. Specifically a 7.159Mhz crystal can be installed for normal operation including high density floppy disk support but be switched to 3.5795Mhz to drive the Sprite Colour Graphics board when required.
This modification requires a 74LS74 to be modified and mounted on top of U4. Five leads are required to connect to other parts of the circuit. Suggested installation method:
Prepare connection points for new clock source:
- Remove Z80 CPU U4 and fold out pin 6 and reinsert.
- Remove 74LS244 U17 and fold out pin 6 and reinsert.
Prepare a 74LS74 for mounting on 74LS10 U4
- Fold up pins 1-6 and 8-13 and snip off the ends leaving the stubs. Pin 7 and 14 remain for connecting to 74LS10 U4.
- Solder a wire from pin 14 to pin 1 and then to pin 11 (brown wire).
- Solder a wire from pin 4 to pin 9 (blue wire)
- Solder wire from pin 13 to pin 5 (green wire)
- Solder wire from pin 12 to pin 7 (yellow wire)
Mounting 74LS74 and connecting flying leads on component side of board:
- Place the 74LS74 over 74LS10 U4 so only pin 7 and 14 are touching.
- Solder pin 14's together and pin 7's together.
- Solder a wire from pin 2 of the 74LS74 to pin 5 of 74LS174 U18 (purple wire)
- Solder a wire from pin 11 of the 74LS74 to pin 12 of 74LS06 U26 (orange wire)
- Solder a wire from pin 3 of 74LS74 to pin 13 74LS06 U26 (red wire).
- Solder a wire from 7 of the 74LS74 to lifted pin 6 of 74LS244 U17 and then to lifted pin 6 of Z80 CPU U24 (yellow wire)
Solder side connections:
- Solder wire from pin 5 of CPU clock P4 to pin 13 74LS06 U26 (red wire).
Software control
Bit 4 of port 70h is used to select the clock speed. The normal condition is for Bit 4 to be set to 0 (low) and this will select the full clock speed of the installed crystal. Writing a 1 (high) to Bit 4 of port 70h will activate the 74LS74 clock divider. The speed switch is currently not supported in ROMWBW. Use of the RTC or speaker will reset Bit 4 to 0 i.e. full speed operation. Further, precalculated software delays or delays based on the initial speed detected at boot time do not take into account the possibility of the speed changing.
Demonstration code:
1 OUT 112,0 2 PRINT "NORMAL SPEED" 3 GOSUB 10 4 OUT 112,8 5 PRINT "SLOW SPEED" 6 GOSUB 10 7 END 10 FOR X=1 TO 64 20 PRINT "."; 30 FOR Y=1 TO 256 40 NEXT Y 50 NEXT X 60 PRINT 70 RETURN
