builderpages:b1ackmai1er:ecb_zilog_peripherals_pcb [2018/07/29 11:25]
b1ackmai1er [sio.asm]
builderpages:b1ackmai1er:ecb_zilog_peripherals_pcb [2018/12/01 23:16] (current)
b1ackmai1er [ROMWBW Customization for SIO serial ports]
Line 23: Line 23:
   * Zilog Peripherals board is supported by configuration. Baud rate selection is supported. Parity, Data and Stop bit changes are not currently supported.   * Zilog Peripherals board is supported by configuration. Baud rate selection is supported. Parity, Data and Stop bit changes are not currently supported.
 +  * Driver changes are available as part of the 2.9.1+ build of ROMWBW.
-[[https://​github.com/​b1ackmai1er/​RomWBW|https://​github.com/​b1ackmai1er/RomWBW]] +[[https://​github.com/​wwarthen/​RomWBW|https://​github.com/​wwarthen/RomWBW]]
builderpages/b1ackmai1er/ecb_zilog_peripherals_pcb.txt · Last modified: 2018/12/01 23:16 by b1ackmai1er
