Z-One
http://www.nomad.ee/micros/z-one/
- Z80 running at up to 4.6Mhz, changeable in MCU firmware
- Memory address space filled with 64K RAM
- CP/M running, with maxed out storage on SD card (16x8MB drives). You need at least 256MB card.
- ATMega1284P as system controller:
- Provides system clock for Z80
- Contains and serves bootloader, monitor, and CP/M binaries
- At startup, patches Z80 bootloader into first 128 bytes of RAM
- SD card interface and initialization
- Console port for Z80-ChibiTerm connection, using UART at 115200
- Heathkit H19 terminal emulation, with special keymappings for WordStar
- Software implemented auxiliary serial port connected to FTDI based USB-Serial converter, up to 19200
- Interval timer with 10ms resolution
- Integrated ChibiTerm
- 80×30 character text with analog VGA connector
- Inverse text and line drawing characters
- PS/2 keyboard, US layout only
- Boots into system monitor if no SD card, that has
- Commands to examine and change memory
- Built in Z80 disassembler
- SD card read/write sector commands
- Can read/write I/O ports
- Can run code, examine registers
- Download Intel Hex file from auxiliary port
- Wait logic for adding 2nd MCU
- Runs from 5V, with modern CMOS Z80 and HCT series logic chips uses less than 70mA
Z-Two
http://www.nomad.ee/micros/z-two/
Like Z-One, but without physical Z80.
- ATMega1284P, running at 18.432MHz is the brains of the operation
- Emulates Z80
- All documented Z80 instruction set, at about 110000 instructions/sec at 18.482MHz ATMega clock
- Enough undocumented ones to pass all Frank Cringle's yaze tests
- Does not emulate undocumented flags 5 and 3
- No external interrupt capabilities
- Can physically address all 512K of memory, although currently only uses 64K for Z80 emulator
- Contains and provides boot loader, monitor, and CP/M binaries
- Heathkit H19 terminal emulation, with special key mappings for WordStar
- Auxiliary serial port connected to FTDI based USB-Serial converter
- Provides interval timer with 10ms resolution
- CP/M 2.2 running, with maxed out storage on SD card (16x8MB drives). You need at least 256MB card.
- The whole system runs from 3.3V, regulated down from 5V supply voltage. Uses less than 10mA
