Pictorial Assembly Guide for partially assembled CB030
CB030 is available as partially assembled pc board where all the surface mount components are soldered and the CPLD is programmed. This pictorial guide show how the remaining through-hole components are assembled step-by-step.
This is the partially assembled CB030, component side and solder side. This is the starting point of the pictorial assembly guide.
Click on a photo for high resolution picture.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56560406.jpg
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56570406.jpg
Add IC sockets
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56580406.jpg
Add discrete capacitors and resistors. Note location of pin 1 of the SIP resistor
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56590406.jpg
Add connector and headers.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56600406.jpg
Finally, add the SIMM72 socket and Compact Flash adapter. Note the pin 1 of SIMM72 socket
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56710413_1.jpg
Completed CB030 with components
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_cb030_cb030_rev1_dsc_56690413.jpg
builderpages/plasmo/cb030/cb030_rev1/pictorial_guide.txt · Last modified: 2020/04/13 21:22 by plasmo
