Z80 Rev1.1 Mezzanine Board for EPM240 Dev Board
While Z80 is specified for 5V operation, selected CMOS Z80 are capable of running at 3.3V. This mezzanine board hosts such Z80 plus a 512K RAM and plugs on top of the EPM240 development board. The two-board Z80 computer can run RomWBW. This is link to rev0 of 3V Z80 which does not have the local 3.3V regulator.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_epm240dev_3vz80_3vz80_rev1.jpg
  • CMOS Z80 selected for 3.3V operation
  • 512K RAM
  • 512 byte flash embedded in EPM240 can boot RomWBW
  • ACIA emulation in EPM240
  • SD card interface
  • RTC module based on DS1302
  • I2C interface
  • RomWBW capable
  • Local 3.3V regulator adjusted to 3.5V
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_epm240dev_3vz80_3vz80_rev1_mezzanine_board.jpg
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_epm240dev_3vz80_3vz80_epm240_side_view.jpg
Boot from embedded 512-byte flash, etc, etc…place holder.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_epm240dev_3vz80_bootsd_romwbw.jpg
Design Files
Schematic
Gerber photoplot files
EPM240 design files
EPM240 design files with fast SD bootstrap (6 seconds), but no RAM disk at drive A
RomWBW image for 3VZ80. The RomWBW will be booted at power up. It takes 23 seconds to load and boot RomWBW from reset.
Note, Serial port for RomWBW will work without hardware handshake, however to transfer files using XM.COM in RomWBW will require a serial port with hardware handshake capability and terminal emulation that supports hardware handshake such as TeraTerm. The handshake signal needs to be CTS (not DTR). Picture below shows modifications to the common 6-pin CP2102 USB-serial adapter to enable hardware handshake.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zrc_modification_to_6-pin_cp2102_to_enable_cts_handshake.jpg
3VZ80 diagnostic, SCREAM. This CPLD contains a simple program that output ASCII character set to serial port continuously and rapidly.
builderpages/plasmo/epm240dev/3vz80/3vz80rev1_1.txt · Last modified: 2025/02/08 22:39 by plasmo
