Proto65 Rev0, a 6502 SBC based on Protor5
This is the link to Proto65 rev 0.1 with a disk-on-module added
Protor5 has a prototype area big enough for a processor, RAM and IDE44 interface. In this project a 6502 CPU along with 128Kx8 RAM and CF interface are prototyped on a protor5 board.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_protor5_proto65_0dsc_62331224.jpg
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_protor5_proto65_0dsc_62321224.jpg
  • Based on protor5
    • EPM7192SQC160 CPLD
    • Reset supervisor
    • CPLD programming header
    • Reset supervisor
    • 2.1mm X 5.5mm power jack
    • Oscillator socket for full and 1/2 size can
    • Serial port interface
    • Prototype area
  • 6502 CPU testbed
  • 128K 25-ns RAM based on CY7C109-25
  • IDE44 interface for CF disk
  • 40-pin expansion connector
TinyLoad is a 256-byte program for Proto65. It is serially loaded into Proto65 at 115200 N81 (assuming CPU is running with 3.68MHz clock). Tinyload can loads other programs in Intel Hex format. After Intel Hex program is loaded, type 'G xxxx' to execute loaded program.
EhBASIC is ported to Proto65 rev0. Load with TinyLoad Hex loader above and type 'G e82a' to run. Copy and paste Mandelbrot program below to demonstrate proper operation of EhBASIC
10 MAXITER=20
20 LET C$=" .,'~!^:;[/<&?oxOX#  "
30 FOR Y=-39 TO 39
40 FOR X=-39 TO 39
50 CREAL=X/20
70 CIMAG=Y/20
80 ZREAL = CREAL
90 ZIMAG = CIMAG
95 COUNT = 1
100 ZM = ZREAL*ZREAL
105 ZN = ZIMAG*ZIMAG
107 ZL = ZM+ZN
110 IF ZL>4 THEN GOTO 170
120 ZR2=ZM-ZN+CREAL
130 ZIMAG=ZREAL*ZIMAG*2+CIMAG
140 ZREAL=ZR2
150 COUNT=COUNT+1
160 IF COUNT<MAXITER THEN GOTO 100
170 PRINT MID$(C$,1+COUNT,1);
180 NEXT X
185 PRINT ""
190 NEXT Y
200 END
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_protor5_proto65_2020-12-27_8-31-30.jpg
builderpages/plasmo/protor5/proto65.txt · Last modified: 2021/01/01 00:46 by plasmo
