Simple80, a simple Z80 SBC with no glue logic
This design was inspired by low-cost Z80 kit listed on eBay. The motivation is to build a CP/M-ready, RC2014-compatible Z80 SBC with part cost of about $20. This is the link to rev1 of Simple80
- Z80 at 7.3728MHz
- Dual serial port SIO
- 128K RAM
- 64K PROM or EEPROM
- 100mm X 100mm pc board
- No glue logic design
Theory of operation
Schematic of SimpleCF, a simple compact flash interface for Simple80
PC board Gerber files of SimpleCF, a simple compact flash interface for Simple80
Bill of Materials for SimpleCF
Simple80 Monitor, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
XMODEM is the file transfer program to bring in all CP/M programs from PC to Z80SBC64. While in monitor, send XMODEM.HEX as Intel Hex file, type 'b2' to boot into CP/M2.2, then type 'save 17 xmodem.com'. XMODEM.COM will be created as the first file on the CP/M disk. To invoke XMODEM to receive files, type 'xmodem filename /r' and go to the terminal program to send file via xmodem.
CPM22DRI is system files for CP/M2.2. Unzip the file to CPM22DRI.ARJ then use XMODEM to transfer it to CP/M. Once transferred, use unarj.com to decompress the files. CPM22DRI image is created using cpmtools.
unarj.com is the CP/M program that decompresses CPM3ALL.ARJ and CPM22DRI.ARJ above. The command is “unarj e filename”
Zorkall is Zork1, Zork2, and Zork3 compressed with arj. Use unarj.com above to decompress.
HTC309 is version 3.09 of HiTech C that has been released into publica domain. It is compressed with arj, use unarj.com above to decompress
CPM3, cbios3, non-banked version. A hardware bug in Simple80 prevents it from having banked memory.
CPM3 loader. Load CPMLDR.HEX at the monitor and type 'g 1100' to start CP/M3.
CP/M 3 distribution files. These are CPM3 executables as distributed by Digital Research. The Simple80 version of cpm3.sys is included.
Updated Simple80 monitor (ver 0.7) with CP/M3 save and boot commands.
Instructions and Manuals
Getting Started with Simple80
For TeraTerm usersthis zipped file contains all CP/M software above plus a TeraTerm macro file that will automatically install all CP/M software in a new CF disk. Unzip the files in C;\teraterm\simple80 and run “newcf.ttl” macro in TeraTerm.
Instruction on compiling and installing CP/M3 on Simple80.
