4×16 Test Pads
Note: Row D is closest to the edge of board; pin 1 is closest to the hexadecimal rotary switch.
Name | Comment | |
A1 | D12 | Data 12 |
A2 | D13 | Data 13 |
A3 | D14 | Data 14 |
A4 | D15 | Data 15 |
A5 | nHALT | 68302 nHALT |
A6 | nUDS | upper data strobe |
A7 | nLDS | lower data strobe |
A8 | R/W | read-write |
A9 | nAS | Address strobe |
A10 | 3.68MHz | 3.68MHz clock |
A11 | CLKCTRL | Enable 3.68MHz clock to 68692 |
A12 | ||
A13 | ||
A14 | ||
A15 | Ground | |
A16 | Ground | |
B1 | D0 | Data 0 |
B2 | D1 | Data 1 |
B3 | D2 | Data 2 |
B4 | D3 | Data 3 |
B5 | D4 | Data 4 |
B6 | D5 | Data 5 |
B7 | D6 | Data 6 |
B8 | D7 | Data 7 |
B9 | D8 | Data 8 |
B10 | D9 | Data 9 |
B11 | D10 | Data 10 |
B12 | D11 | Data 11 |
B13 | ||
B14 | Ground | |
B15 | Ground | |
B16 | Ground | |
C1 | A13 | Address 13 |
C2 | A14 | Address 14 |
C3 | A15 | Address 15 |
C4 | A16 | Address 16 |
C5 | A17 | Address 17 |
C6 | A18 | Address 18 |
C7 | A19 | Address 19 |
C8 | A20 | Address 20 |
C9 | nCS1 | To nCS1 of 68302 via 330 series resistor |
C10 | nCS2 | To nCS2 of 68302 via 330 series resistor |
C11 | nCS3 | To nCS3 of 68302 via 330 series resistor |
C12 | nCS0 | To nCS0 of 68302 via 330 series resistor |
C13 | ||
C14 | Ground | |
C15 | Ground | |
C16 | Ground | |
D1 | A1 | Address 1 |
D2 | A2 | Address 2 |
D3 | A3 | Address 3 |
D4 | A4 | Address 4 |
D5 | A5 | Address 5 |
D6 | A6 | Address 6 |
D7 | A7 | Address 7 |
D8 | A8 | Address 8 |
D9 | A9 | Address 9 |
D10 | A10 | Address 10 |
D11 | A11 | Address 11 |
D12 | A12 | Address 12 |
D13 | ||
D14 | ||
D15 | Ground | |
D16 | Ground |
