Getting Started with CB030, Rev0
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_tiny030_cb030_cb030_r0_annotated_f.jpg
This guide assume you already have a fully assembled CB030 rev0 as shown in the picture above.
Connecting console serial port
The console serial port is the 6-pin connector labelled 'P6'. The pin assignment is for direct connection to a CP2102 USB-serial adapter as shown in the picture below. Set the terminal emulator to 38400 N-8-1
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_tiny030_cb030_cb030_console_serial.jpg
Powering Up
CB030 requires regulated 5V, 1amp. The power plug is 2.5mm X 5.5mm which is not compatible with the more popular 2.1mm X 5.5mm connector.
Apply power to CB030 and the following message will display after about 1 second delay:
CB030Bug
1/17/20 v0.3, type “he” for help
I cache on
Type 'he' to display the help menu
> he Commands are in lower case, <>optional, []mandatory
dm [address] <count>
dr <a|d|a0-a7|d0-d7> Display all registers if no parameter
mm [address] <value> If only address entered, a submenu will follow:
. terminates submenu session
- go back one word address
[value] modify current address and display next address
CR not modify current address but display next address
mr [a0-a7|d0-d7] <value> If only register entered, a submenu will follow:
- go back one register
[value] modify current register and display next register
CR not modify current register but display next register
go <from_addr> <to_addr> If no address specified, use save register values
bp <addr> If no address specified, display current break point
special case: bp 0 removes breakpoint
du [address] <line count> dump specified number of lines
CP/M68K
To run CP/M68K from the monitor, type 'go 15000' and the CP/M68K A> prompt will display
Drive A is read-only drive reside on EPROM. It contains the formatting software, 'init.68k' and file transfer file, 'gkermit.68k'
Drive B-E are 8-megabyte read-write drives reside on DiskOnModule.
builderpages/plasmo/tiny030/cb030/getting_started_cb030.txt · Last modified: 2020/01/24 21:35 by plasmo
