builderpages:plasmo:tinyz280:tinyz280_construction [2018/02/07 08:39]
builderpages:plasmo:tinyz280:tinyz280_construction [2018/02/07 08:44] (current)
Line 39: Line 39:
     27       ​2 ​ S1,S2                           ​SW_PUSHBUTTON ​        ​MINI-4     27       ​2 ​ S1,S2                           ​SW_PUSHBUTTON ​        ​MINI-4
 </​code>​ </​code>​
 +Assembly procedure:
   - Solder U2, EPM7128SQC100,​ with a fine tip soldering pen. Use plenty of flux.   - Solder U2, EPM7128SQC100,​ with a fine tip soldering pen. Use plenty of flux.
   - Install R32 and R31. They are 0805 resistors and value can be lowered to 470 ohms for brighter display   - Install R32 and R31. They are 0805 resistors and value can be lowered to 470 ohms for brighter display
Line 65: Line 68:
   - Do not populate R11 and R15   - Do not populate R11 and R15
   - Install 5 bypass capacitors, C4-C8   - Install 5 bypass capacitors, C4-C8
 +{{https://​www.retrobrewcomputers.org/​lib/​plugins/​ckgedit/​fckeditor/​userfiles/​image/​builderpages/​plasmo/​tinyz280/​dsc_33210127.jpg?​direct&​600x636}}
builderpages/plasmo/tinyz280/tinyz280_construction.txt · Last modified: 2018/02/07 08:44 by plasmo
