builderpages:plasmo:z280rc [2018/08/31 21:37]
builderpages:plasmo:z280rc [2018/12/02 23:37]
Line 50: Line 50:
 {{:​builderpages:​plasmo:​z280rc:​z280rc_r0_1.zip|Gerber }}  photoplots. The boards were manufactured by Seeed Studio {{:​builderpages:​plasmo:​z280rc:​z280rc_r0_1.zip|Gerber }}  photoplots. The boards were manufactured by Seeed Studio
-Bill of Material for Z280RC+{{:​builderpages:​plasmo:​zz80rc:​z280rc_bom.txt|Bill of Material}}  ​for Z280RC
 [[:​builderpages:​plasmo:​z280rc:​z280rc_r0_ec|Engineering Changes ]] [[:​builderpages:​plasmo:​z280rc:​z280rc_r0_ec|Engineering Changes ]]
 +Pictorial [[:​builderpages:​plasmo:​z280rc:​z280rc_assembly|assembly guide]]
 Altera EPM7128 CPLD {{:​builderpages:​plasmo:​z280rc:​z280rc_29_5mhz.zip|design file}} ​ for 29.4912MHz system clock. Altera EPM7128SQC100 {{:​builderpages:​plasmo:​z280rc:​z280rc_29_5_prog.zip|programming file}} ​ for 29.4912MHz system clock. Altera EPM7128 CPLD {{:​builderpages:​plasmo:​z280rc:​z280rc_29_5mhz.zip|design file}} ​ for 29.4912MHz system clock. Altera EPM7128SQC100 {{:​builderpages:​plasmo:​z280rc:​z280rc_29_5_prog.zip|programming file}} ​ for 29.4912MHz system clock.
Line 60: Line 62:
   * ZZMon – {{:​builderpages:​plasmo:​z280rc:​zzmon_099.zip|monitor}} ​ rev 0.99 for Z280RC. Assembled with Zilog ZDS v3.68   * ZZMon – {{:​builderpages:​plasmo:​z280rc:​zzmon_099.zip|monitor}} ​ rev 0.99 for Z280RC. Assembled with Zilog ZDS v3.68
   * LoadnGo – {{:​builderpages:​plasmo:​z280rc:​loadngo.zip|load file}} ​ to start up ZZMon in UART bootstrap mode   * LoadnGo – {{:​builderpages:​plasmo:​z280rc:​loadngo.zip|load file}} ​ to start up ZZMon in UART bootstrap mode
-  * CP/M2.2, {{:​builderpages:​plasmo:​tinyz280:​cpm22all_asm.zip|CPM22ALL}} ​ to be assembled with Zilog ZDS v3.68. This is the entire CP/M2.2 including BDOS, CCP, and BIOS +  * CP/M2.2, {{:​builderpages:​plasmo:​z280rc:​cpm22all_asm.zip|CPM22ALL}} ​ to be assembled with Zilog ZDS v3.68. This is the entire CP/M2.2 including BDOS, CCP, and BIOS
-  * CP/M2.2 {{:​builderpages:​plasmo:​tinyz280:​cpm22all_hex_loadfile.zip|Intel Hex load file}} ​ to be loaded by ZZMon at location 0xDC00-0xFFFF and then copy to CF track 0 using the '​C2'​ command+  * CP/M2.2 {{:​builderpages:​plasmo:​z280rc:​cpm22all_hex_loadfile.zip|Intel Hex load file}} ​ to be loaded by ZZMon at location 0xDC00-0xFFFF and then copy to CF track 0 using the '​C2'​ command
   * CP/M3 {{:​builderpages:​plasmo:​tinyz280:​ldrbios.zip|LDRBIOS}} ​ to be assembled with ZMAC into LDRBIOS.REL and then linked in CP/M as follow: LINK CPMLDR[L100]=CPMLDR,​ LDRBIOS   * CP/M3 {{:​builderpages:​plasmo:​tinyz280:​ldrbios.zip|LDRBIOS}} ​ to be assembled with ZMAC into LDRBIOS.REL and then linked in CP/M as follow: LINK CPMLDR[L100]=CPMLDR,​ LDRBIOS
   * CP/M3 {{:​builderpages:​plasmo:​tinyz280:​cbios3.zip|CBIOS3}} ​ (non-banked) to be assembled with ZMAC into CBIOS3.REL and then linked in CP/M as follow: LINK BIOS3[OS]=CBIOS3,​SCB   * CP/M3 {{:​builderpages:​plasmo:​tinyz280:​cbios3.zip|CBIOS3}} ​ (non-banked) to be assembled with ZMAC into CBIOS3.REL and then linked in CP/M as follow: LINK BIOS3[OS]=CBIOS3,​SCB
Line 75: Line 77:
   * ZZMon [[:​builderpages:​plasmo:​z280rc:​zzmon_man_099|operating manual ]]   * ZZMon [[:​builderpages:​plasmo:​z280rc:​zzmon_man_099|operating manual ]]
   * Z280RC [[:​builderpages:​plasmo:​tinyz280:​software_build|software build procedures ]]<​-(need update)   * Z280RC [[:​builderpages:​plasmo:​tinyz280:​software_build|software build procedures ]]<​-(need update)
-  * Creating ​a [[:​builderpages:​plasmo:​z280rc:​new_cfdisk|new CF disk]] for Z280RC+  * Create ​a [[:​builderpages:​plasmo:​z280rc:​new_cfdisk|new CF disk]] for Z280RC
 +  * Create a [[:​builderpages:​plasmo:​z280rc:​newcf_byte_swap|new CF disk with correct byte ordering]] for Z280RC <- 10/2/2018 this is work in progress, files not ready for use
 Reference Reference
builderpages/plasmo/z280rc.txt · Last modified: 2018/12/02 23:37 by plasmo
