Pictorial Assembly Instruction of ZZ80RC, Rev 1
The sequence of soldering is start from the lowest height components to the tallest components. This keeps the components pressed against the pc board as the soldering progress.
Bare board component side
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41111219.jpg
Bare board solder side
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41121219.jpg
Resistors, SIP resistor and bypass capacitors are soldered first.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41131219.jpg
Two IC under the RAM, 74ALS138 and 74LS32 are soldered directly to the pc board. 1.8432MHz baud rate oscillator is also soldered directly to pc board.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41141219.jpg
IC sockets are soldered next.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41151219.jpg
Serial connector and RC2014 bus are soldered next.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41171219.jpg
CR1220 battery holder and reset push button are soldered next.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41181219.jpg
Jumper headers are next.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41191219.jpg
Socket for Z280, power jack 2.1mm x 5.5mm and voltage supervisor are next
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41201219.jpg
Compact flash adapter is soldered last
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_zz80cf_dsc_41211219.jpg
builderpages/plasmo/zz80cf/assembly_instruction.txt · Last modified: 2018/12/19 22:19 by plasmo
