Jose Luis Collado 2016/09/11
Portions of the hardware and designs on this page are based on Grant Searle's original work, which was published with the following license: “By downloading these files you must agree to the following: The original copyright owners of ROM contents are respectfully acknowledged. Use of the contents of any file within your own projects is permitted freely, but any publishing of material containing whole or part of any file distributed here, or derived from the work that I have done here will contain an acknowledgement back to myself,GrantSearle, and a link back to this page. Any file published or distributed that contains all or part of any file from this page must be made available free of charge.”
Welcome to my recently completed Project using the awesome Papilio Duo platform with the Classic Computing Shield (Xilinx Spartan 6) It's a migration of Grant Searle's brillant work called MULTICOMP, consisting in a flexible FPGA based architecture for implementing old style 8 bit Retro-computers using Z80, 6502 & 6809 “Soft-core” CPU's. You can take a look at the original Project, based on an Altera Cyclone II dev board, following this link: (Link to Grant's web site)
4. In my first attempt I adapter the CPU and Baudrate clock generators, to use the Papilio's 32 MHz OSC instead of the original 50 MHz, but I ran into timing problems converting the many clock -dependant constants in the design. So I decided to generate a new 50 MHz clock using the DCM & PLL Wizard.
Hope you enjoy it !
I've attached some pictures of my working system and the full VHDL ISE 14.7 Project tree files, including an already generated “bit” file for transferring it to the Papilio Duo with the Computing Shield attached (default serial port baudrate is 9600, 8N1 no handshake).
I've also included ready to go SD card image (SDHC only, 2 GB) with all the CP/M paritioning work allready done including a very comprehensive software collection courtesy of Oscar Vermeulen (drives A to D, Users 0 to 9).
Link to Project files:
https://app.box.com/s/g5wiv2aobx9d4ctypjnvyp9wpgtqj43f
Link to SD Card image with CP/M 2.2 Software Collection:
https://app.box.com/s/jlade3pejz5t921ldz0qfg2obrsi1kjn
Image Gallery:
builderpages/positron/start.1473798058.txt.gz · Last modified: 2016/09/13 16:20 by positron
