ECB ATB Active Termination Board
I've completed the new ATB version and done some simple tests with my scope on the ECB bus.
I set the voltage to 2.7Volt.
All tests:
4×4 ECB bus board with:
SBC with 74ls244/245 bus drivers.
PropIO board with 74ls244/245 bus drivers (same brand as SBC).
Prototype III board to tap into bus pins easier.
And ATB new version.
Power supply on the 4×4 = 4.96-5.01Volt
TextImage
ATB completed:
Note that the RN5 only needs 6 pins, but pin1 is connected to square pad under the board.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_speed3ple_images_img_20210325_201911small.jpg
This is A0 with no ATBwww.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_speed3ple_images_img_20210325_201429small.jpg
And this is A0 with ATB:
ATB draw about 100mA.
The signal on A0 looks cleaner on top with ATB, but there is some ringing added there.
Rise times are about the same as far as I could see.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_speed3ple_images_img_20210325_201444small.jpg
This is D0 without ATB:www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_speed3ple_images_img_20210326_182647small.jpg
…and here is D0 with ATB.
This kind of noise does not look good??
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_speed3ple_images_img_20210326_183930small.jpg
Experiment to clean up D0-D7 signals
I changed the RR1 from 270ohm to 10K and that helped (No noise) but 10K is basically the same as turn Active Termination off for D0-D7?
When the RR1 was changed to 10k I got the same curves/pattern on my scope as no ATB. I didn't try 4K7 or 2K2. Maybe my bus is noisy on D0-7? I tried different 74xxx245 (HCT, ACT and AHCT) but could get the ATB to clean up D0-7 lines with ATB.
I even tried different OpAmps and also tuned the voltage on the ATB from 2.2 to 3volts.
builderpages/speed3ple/ecb-atb.txt · Last modified: 2021/03/28 15:02 by speed3ple
