ECB RamFloppy board:
This is the R11 version.
Built with 8 x AS6C4008-55 and a mix of HC, AHCT and LS logic.
Lesson learned: If You try to use 2 RamFloppy boards at the same time, pay attention to current draw from the power supply. My first power supply could not keep up; 5volt was down to 4,45volt and there was trouble booting system.
I used a SMD version of the TLC7705D on a small adapter board. Seems to work.
Good read/write speeds!
| Text | Images |
| ECB-RamFloppy pcb completed | ![]() |
| ECB-RamFloppy in use |
