Hi There
- The Apple II - I still have a IIe and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch.
- Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios.
- Building electronic things - Now this is where RetroBrewComputers has just recently come into my life
- Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters
RetroBrewComputer Build
ECB
- SBCV2 - Fully built and operational running romwbw 2.71. Currently running the Z80 at 4Mhz. Powered directly from the backplane
PSU at this stage. - 12-Slot Backplane 505-6508 - Built and 1/2 populated with connectors. :builderpages:trick-1:backplane.jpg
- ECB Bus Monitor - working :builderpages:trick-1:busmon.jpg
- ECB Disk I/O V3.0 - working :builderpages:trick-1:diskio.jpg
- ECB cvdu - working :builderpages:trick-1:cvdu.jpg
- ECB propio - Pending Propeller programming :builderpages:trick-1:propio.jpg
- ECB ProtoBoard III - working
- EuroCard Rack - I got a great deal from this gumtree seller in Australia who has a range of racks/PSU/card guides, front pannel hardware etc https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514
- 250W ATX Slimline Switch Mode Power Supply with ATX socket on breadboard and switch between the green wire and ground (sorry that's really not technical)
- MiniMax8085 - tested and working well
Built but yest to be tested
- ECB ProtoBoard III x1
- ECB 68030
- ECB MF-PIC
- SBC6120-rbc-edition - This is now built
- ECB VGA3
Pending final parts
- ECB 4UART-USB
- ECB Dual-SD-Card
- ECB Sprite Video Card
To be built
- CPU280
- REH-RBC-IDE
- 3 Slot ECB Backplane
This is a rather bad photo but shows my initial setup in an ABS Rack Case. This is now in a metal EuroCard Rack case (photo pending)
September 2017 Update
Well after a big session I now have my RBC running a custom ROMWBW 2.4.8 with the following hardware. See the forum posts around DISKIO and CVDU for information on what was done there to make it all work.
- CVDU - terminal Video and Keyboard
- DISKIOv3 - 1.44M FDD and Physical HDD
- Z80 @ 10Mhz (see forum post about using Crystals instead of Oscillators)
- Busmonitor
- Prototype card with some basic lights to flash on and off for getting the hang of programming.
The following is the current setup
