builderpages:trick-1:start [2017/07/05 23:29] trick-1 |
builderpages:trick-1:start [2019/11/15 19:24] trick-1 |
* The Apple II - I still have a II//e and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch. // | * The Apple II - I still have a II//e and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch. // |
* //Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios. // | * //Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios. // |
* //Building electronic things - Now this is where RetroBrewComputers has just recently come into my life {{https://www.retrobrewcomputers.org/lib/images/smileys/icon_smile.gif?nolink&}}// | * //Building electronic things - Now this is where RetroBrewComputers has just recently come into my life // |
* //Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters // | * //Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters // |
//**RetroBrewComputer Build** // | //**RetroBrewComputer Build** // |
* //SBCV2 - Fully built and operational running romwbw 2.71. Currently running the Z80 at 4Mhz. Powered directly from the backplane <del>PSU at this stage</del>.// | * //SBCV2 - Fully built and operational running romwbw 2.71. Currently running the Z80 at 4Mhz. Powered directly from the backplane <del>PSU at this stage</del>.// |
* //12-Slot Backplane 505-6508 - Built and 1/2 populated with connectors. // | * //12-Slot Backplane 505-6508 - Built and 1/2 populated with connectors. {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=646ca3&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=c5963d&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=02413e&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=2f2fe0&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=6bc3fe&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=480284&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=dacc63&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f81a38&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f2469c&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=0d060e&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=59ac1a&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=4285a3&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=builderpages:trick-1:backplane.jpg?linkonly|:builderpages:trick-1:backplane.jpg}} // |
* //ECB Bus Monitor - built pending proper configuration // | * //ECB Bus Monitor - working {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=e9ba0c&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=eb2f1f&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=831fa6&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=bfc05d&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=eaa775&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=4c98a9&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=08f173&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f14e57&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=9cc45d&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=63f6c6&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=16b8d4&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=8002ee&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=builderpages:trick-1:busmon.jpg?linkonly|:builderpages:trick-1:busmon.jpg}} // |
* //ECB Disk I/O V3.0 - pending 8255 and testing// | * //ECB Disk I/O V3.0 - working {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=5743b0&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=de2cc4&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=26a8d2&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=ccd66a&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f5bc64&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=1f66f6&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=8b55a6&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=78d8e0&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=1998bc&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=db340e&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=54a6fe&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=d5b98b&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=builderpages:trick-1:diskio.jpg?linkonly|:builderpages:trick-1:diskio.jpg}} // |
* //ECB cvdu - pending 82C42 and the mini din connectors remain to be installed.// | * //ECB cvdu - working {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=00bc7b&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=4f6b0a&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=68c75b&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=7a14a7&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=72792f&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=1548c0&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=53b05a&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=fb4e25&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=4ad45d&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=57578b&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=993133&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=659364&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=builderpages:trick-1:cvdu.jpg?linkonly|:builderpages:trick-1:cvdu.jpg}} // |
* //ECB propio - socketed and most components, pending PropIO, Resistor packs, mini din and SD Card// | * //ECB propio - Pending Propeller programming {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=0514d5&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=5e88bd&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=8622fc&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=ae9fda&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=174d89&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=0e1f1a&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=30ec65&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=1fa137&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=007bff&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=a24969&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=d12c23&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=878fa0&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=builderpages:trick-1:propio.jpg?linkonly|:builderpages:trick-1:propio.jpg}} // |
| * ECB ProtoBoard III - working |
* EuroCard Rack - I got a great deal from this gumtree seller in Australia who has a range of racks/PSU/card guides, front pannel hardware etc [[https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514|https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514]] | * EuroCard Rack - I got a great deal from this gumtree seller in Australia who has a range of racks/PSU/card guides, front pannel hardware etc [[https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514|https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514]] |
* 250W ATX Slimline Switch Mode Power Supply with ATX socket on breadboard and switch between the green wire and ground (sorry that's really not technical) | * 250W ATX Slimline Switch Mode Power Supply with ATX socket on breadboard and switch between the green wire and ground (sorry that's really not technical) |
| * MiniMax8085 - tested and working well |
**ECB Transputer Link Interface (aka TLI )** | Built but yest to be tested |
This is something I want to try and bring to the community. It is slow progress and maybe one day I will hopefully publish a board. I have started to design the link interface leveraging the prototype board work that is already in existence and borrowing heavily from Das Transputer Buch (yes that book really is a fantastic source of information). | * ECB ProtoBoard III x1 |
| * ECB 68030 |
| * ECB MF-PIC |
| * SBC6120-rbc-edition - This is now built |
| * ECB VGA3 |
The link interface would allow the connection of an ECB based system to a Transputer network. The ECB Tram Carrier Card is a candidate. | Pending final parts |
Mar/17 - Design almost finalised, just need to complete the bus connections before sending to PCBWay ([[http://www.pcbway.com/|http://www.pcbway.com/]]) for the first run. | * ECB 4UART-USB |
| * ECB Dual-SD-Card |
| * ECB Sprite Video Card |
**ECB TRAM Carrier Card (aka 4TC2 )** | To be built |
The idea here is to create a simple ECB card that can support 1-4 INMOS TRAM's. <del>Have started work but original design needs some revision to make it more aligned with standard practices.</del> | * CPU280 |
| * REH-RBC-IDE |
| * 3 Slot ECB Backplane |
Have finalised a design | This is a rather bad photo but shows my initial setup in an ABS Rack Case. This is now in a metal EuroCard Rack case (photo pending) |
* Supports 4 TRAM's | {{:builderpages:trick-1:ecb_system.jpg?nolink&500x375|ecb_system.jpg}} |
* cascade to multiple boards | |
* Power from EuroConnector or external standalone | |
* Breakout for all unused links | |
I sent the files to PCBway ([[http://www.pcbway.com/|http://www.pcbway.com/]]) for manufacture. Once tested will put this up in the ECB boards section with all the right gerber files. | September 2017 Update |
Jan/17 - Boards arrived and have been assembled. Some minor layout, screen print and design issues to resolve but they work! | Well after a big session I now have my RBC running a custom ROMWBW 2.4.8 with the following hardware. See the forum posts around DISKIO and CVDU for information on what was done there to make it all work. |
Feb/17 - Version 0.4 of the board is now confirmed fully working however a number of design modifications have been made and Version 0.5 of the board is pending. | * CVDU - terminal Video and Keyboard |
| * DISKIOv3 - 1.44M FDD and Physical HDD |
| * Z80 @ 10Mhz (see forum post about using Crystals instead of Oscillators) |
| * Busmonitor |
| * Prototype card with some basic lights to flash on and off for getting the hang of programming. |
the following is the image of the version 0.4 board with 4 INMOS TRAM's installed. | The following is the current setup |
{{ :builderpages:trick-1:4tc2.jpg?nolink&500x250 }} | {{:builderpages:trick-1:rbcsep2017.jpg?nolink&400x300|rbcsep2017.jpg}} |
Jul/17 - Version 0.5 of the board has been finalised and sent for manufacture. | |
**ECB Transputer CPU Card (2TC2)** | |
This card is in initial design phase but is aiming to be | |
* Minimum 2x Transputer CPUs | |
* Minimum 1MB SRAM | |
* head and tail connector | |
* breakout of unused links | |
* Power from EuroConnector or external for standalone | |
This is ideal for those who want to put a Transputer in their system but maybe cannot get hold of a TRAM module. | |
**ECB Manual Cross Bar Switch (MCBS)** | |
This card has been designed but is yet to be manufactured for testing. The card allows the connection of all unused links from other boards via a single ribbon cable and then allow for the configuration to be set with jumper cables. This will allow for maximum configuration of a given set of Transputers from either 2TC2 or 4TC2. | |
//**SBC** // | |
SBC6120-rbc-edition | |
Thanks to Andrew the kit of parts has arrived. Looking forward to building this up. | |
