Hi There
- The Apple II - I still have a IIe and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch.
- Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios.
- Building electronic things - Now this is where RetroBrewComputers has just recently come into my life
- Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters
RetroBrewComputer Build
ECB
- SBCV2 - Fully built and operational running romwbw 2.71. Currently running the Z80 at 4Mhz. Powered directly from the backplane
PSU at this stage. - 12-Slot Backplane 505-6508 - Built and 1/2 populated with connectors. :builderpages:trick-1:backplane.jpg
- ECB Bus Monitor - built pending proper configuration :builderpages:trick-1:busmon.jpg
- ECB Disk I/O V3.0 - pending 8255 and testing :builderpages:trick-1:diskio.jpg
- ECB cvdu - pending 82C42 and the mini din connectors remain to be installed.:builderpages:trick-1:cvdu.jpg
- ECB propio - socketed and most components, pending PropIO, Resistor packs, mini din and SD Card :builderpages:trick-1:propio.jpg
- EuroCard Rack - I got a great deal from this gumtree seller in Australia who has a range of racks/PSU/card guides, front pannel hardware etc https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514
- 250W ATX Slimline Switch Mode Power Supply with ATX socket on breadboard and switch between the green wire and ground (sorry that's really not technical)
Yet to be built
- In hand and some assembly started.
- ECB ProtoBoard III
- ECB 68030
- ECB MF-PIC
- SBC6120-rbc-edition - Thanks to Andrew the kit of parts has arrived. Looking forward to building this up.
- MiniMax8085
- Ordered pending arrival
- ECB VGA3
- ECB Dual-SD-Card
- ECB 4UART-USB
- Pending purchase
- CPU280
- CPU280 IDE (I forget right now what that's called)
- 3 Slot ECB Backplane
This is a rather bad photo but shows my initial setup in an ABS Rack Case. This is now in a metal EuroCard Rack case (photo pending)
- 32bit CPU (T4xx/T8xx)
- 4x 10/20Mbit/s serial links for communication to up to 4 other Transputers
- Programmable in Occam, C, Pascal
- Run O/S such as Minix and Helios
What is a TRAM
TRAM's are silly expensive on ebay! So probably not the place to start if you don't have any. Much better to wait for the ECB Transputer CPU Card.
Basic Transputer System
- Host - in this case the ECB based machine
- Host Adapater Card or Transputer link Interface (see ECB Transputer Link Interface below)
- Transputer Network - TRAM Carrier Boards or non-TRAM based CPU Cards (see ECB TRAM Carrier Card and Transputer CPU Card below)
the basic setup is
Have finalised a design
- Supports 4 TRAM's
- cascade to multiple boards
- Power from EuroConnector or external standalone
- Breakout for all unused links
Gerber files for version 0.4 of the board :builderpages:trick-1:4tc2v0.4.zip
Jan/17 - Boards arrived from PCBway, well packed, professionally made and in cool red! Have assembled and tested 1 unit. Some minor layout, screen print and design issues to resolve but they work!
v0.4 plugged into Axel @ Geekdot's Apple II Transputer Link Card
Proof of life. Simple BASIC program using PEEK/POKE to interact and confirm that there is a Transputer connected.
The following is the image of the version 0.4 board with 4 INMOS TRAM's installed.
Jul/17 - Version 0.5 of the board has been finalised and sent for manufacture (http://www.pcbway.com).
The following files are what have been sent. Please note that this version has had some modifications and re-routing from v0.4 of the board and as yet have not been tested.
- Gerber Files :builderpages:trick-1:4tc2v0.5.zip
ECB Transputer CPU Card (TCPU)
- 1-2x Transputer CPUs on board
- Minimum 1MB SRAM
- head and tail connector
- breakout of unused links
- Power from EuroConnector or external for standalone
ECB Transputer CPU Card -TCPUv0.1
6/7/2017 Have decided that the first development version will be just the Transputer, link connections, power and mandatory support circuit all other pins from the Transputer will be broken out into a header so that I can experiment with memory and other peripherals.
KiCAD and Gerber Files :builderpages:trick-1:ecbtcpu_version_0.1.zip
7/7/2017 Version 0.1 files have been sent to manufacture at (http://www.pcbway.com)…
This card has been designed but is yet to be manufactured for testing. This is mainly because I have not built enough ECB based Transputer cards to warrant doing so. In theory it is a manual version of the INMOS IMSC004 Cross Bar Switch. Obviously not software configurable.
The card allows the connection of all unused links from other ECB Transputer boards via a single ribbon cable and then allow for the link configuration to be set with jumper cables. This will allow for maximum configuration of a given set of Transputers cards from either Final version of TCPU or 4TC2v0.5 and above.
The following are the KiCAD Design and Gerber Files. I have never had this board fabricated but as you can see it is rather simple.
