Hi There
  • The Apple II - I still have a IIe and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch.
  • Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios.
  • Building electronic things - Now this is where RetroBrewComputers has just recently come into my life
  • Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters
RetroBrewComputer Build
ECB
Yet to be built
  • In hand and some assembly started.
    • ECB ProtoBoard III x1
    • ECB 68030
    • ECB MF-PIC
    • SBC6120-rbc-edition - Thanks to Andrew the kit of parts has arrived. Looking forward to building this up.
    • MiniMax8085
    • ECB VGA3
    • ECB Dual-SD-Card
    • ECB 4UART-USB
    • CPU280
    • CPU280 IDE (I forget right now what that's called)
  • Pending purchase
    • 3 Slot ECB Backplane
This is a rather bad photo but shows my initial setup in an ABS Rack Case. This is now in a metal EuroCard Rack case (photo pending)
September 2017 Update
Well after a big session I now have my RBC running a custom ROMWBW 2.4.8 with the following hardware. See the forum posts around DISKIO and CVDU for information on what was done there to make it all work.
  • CVDU - terminal Video and Keyboard
  • DISKIOv3 - 1.44M FDD and Physical HDD
  • Z80 @ 10Mhz (see forum post about using Crystals instead of Oscillators)
  • Busmonitor
  • Prototype card with some basic lights to flash on and off for getting the hang of programming.
The following is the current setup
  • 32bit CPU (T4xx/T8xx)
  • 4x 10/20Mbit/s serial links for communication to up to 4 other Transputers
  • Programmable in Occam, C, Pascal
  • Run O/S such as Minix and Helios
What is a TRAM
TRAM's are silly expensive on ebay! So probably not the place to start if you don't have any. Much better to wait for the ECB Transputer CPU Card.
Basic Transputer System
  • Host - in this case the ECB based machine
  • Host Adapater Card or Transputer link Interface (see ECB Transputer Link Interface below)
  • Transputer Network - TRAM Carrier Boards or non-TRAM based CPU Cards (see ECB TRAM Carrier Card and Transputer CPU Card below)
the basic setup is
Have finalised a design
  • Supports 4 TRAM's
  • cascade to multiple boards
  • Power from EuroConnector or external standalone
  • Breakout for all unused links
Gerber files for version 0.4 of the board :builderpages:trick-1:4tc2v0.4.zip
Jan/17 - Boards arrived from PCBway, well packed, professionally made and in cool red! Have assembled and tested 1 unit. Some minor layout, screen print and design issues to resolve but they work!
v0.4 plugged into Axel @ Geekdot's Apple II Transputer Link Card
Proof of life. Simple BASIC program using PEEK/POKE to interact and confirm that there is a Transputer connected.
The following is the image of the version 0.4 board with 4 INMOS TRAM's installed.
Jul/17 - Version 0.5 of the board has been finalised and sent for manufacture (http://www.pcbway.com).
Jul/17 - Version 0.5 boards have arrived.
The following files are what have been sent. Please note that this version has had some modifications and re-routing from v0.4 of the board and as yet have not been tested.
ECB Transputer CPU Card (TCPU)
  • 1-2x Transputer CPUs on board
  • Minimum 1MB SRAM
  • head and tail connector
  • breakout of unused links
  • Power from EuroConnector or external for standalone
ECB Transputer CPU Card -TCPUv0.1
6/7/2017 Have decided that the first development version will be just the Transputer, link connections, power and mandatory support circuit all other pins from the Transputer will be broken out into a header so that I can experiment with memory and other peripherals.
KiCAD and Gerber Files :builderpages:trick-1:ecbtcpu_version_0.1.zip
7/7/2017 Version 0.1 files have been sent to manufacture at (http://www.pcbway.com)…
Jul/17 0.1 boards have arrived….
Sep/17 Version 0.1 board finally built, tested and working!.
errata so far
  • Error should have been presented as notError - need to add a 74LS04 inverter to the next version of the board
  • Link0 not presented in the uplink header. Link3 is there instead.
  • Link Speed Jumpers need to be added
  • Tidy up link locations and label
The following shows the current state. You can see the 74LS04 on a vero board behind the main board. Also the brown wire jumper down to the breakout where the link speed connections ended up. Plugged into my IIe running the basic test code and those magic words “32 BIT TRANSPUTER FOUND”
next step is to build out some memory options
ECB Transputer CPU Card -TCPUv0.2
In planning but will be looking to fix the errors of version 0.1 and add the first go at memory.
Also considering adding the bus to link interface circuit so that the board will work standalone in an ECB system but that might wait until version 0.3
This card has been designed but is yet to be manufactured for testing. This is mainly because I have not built enough ECB based Transputer cards to warrant doing so. In theory it is a manual version of the INMOS IMSC004 Cross Bar Switch. Obviously not software configurable.
The card allows the connection of all unused links from other ECB Transputer boards via a single ribbon cable and then allow for the link configuration to be set with jumper cables. This will allow for maximum configuration of a given set of Transputers cards from either Final version of TCPU or 4TC2v0.5 and above.
The following are the KiCAD Design and Gerber Files. I have never had this board fabricated but as you can see it is rather simple.
KiCAD :builderpages:trick-1:ecb_crosspatch_20170706.zip
Gerber :builderpages:trick-1:ecbtcrosspatch.zip
builderpages/trick-1/start.1506253889.txt.gz · Last modified: 2017/09/24 07:51 by trick-1
