Hi There
- The Apple II - I still have a IIe and a II europlus that I have restored and collected a variety of cards for over the years. I have also designed (opto coupled parallel I/O card) and in the process of finalising a build of a Transputer link card with modification from Das Transputer Buch.
- Transputers - I caught the transputer bug in the late 1990's and today have a modest collection of which most runs Helios.
- Building electronic things - Now this is where RetroBrewComputers has just recently come into my life
- Other computing related things such as SunOS/FreeBSD/OpenBSD/Ubuntu and Nvidia CUDA/Parallella/Intel Xeon Phi Clusters
RetroBrewComputer Build
ECB
- SBCV2 - Fully built and operational running romwbw 2.71. Currently running the Z80 at 4Mhz. Powered directly from the backplane
PSU at this stage. - 12-Slot Backplane 505-6508 - Built and 1/2 populated with connectors. :builderpages:trick-1:backplane.jpg
- ECB Bus Monitor - working :builderpages:trick-1:busmon.jpg
- ECB Disk I/O V3.0 - working :builderpages:trick-1:diskio.jpg
- ECB cvdu - working :builderpages:trick-1:cvdu.jpg
- ECB propio - Pending Propeller programming :builderpages:trick-1:propio.jpg
- ECB ProtoBoard III - working
- EuroCard Rack - I got a great deal from this gumtree seller in Australia who has a range of racks/PSU/card guides, front pannel hardware etc https://www.gumtree.com.au/s-ad/blacktown-area/other-electronics-computers/din41612-eurocard-frame-card-guides-183mm-jg1/1129976514
- 250W ATX Slimline Switch Mode Power Supply with ATX socket on breadboard and switch between the green wire and ground (sorry that's really not technical)
- MiniMax8085 - tested and working well
Built but yest to be tested
- ECB ProtoBoard III x1
- ECB 68030
- ECB MF-PIC
- SBC6120-rbc-edition - This is now built
- ECB VGA3
Pending final parts
- ECB 4UART-USB
- ECB Dual-SD-Card
- ECB Sprite Video Card
To be built
- CPU280
- REH-RBC-IDE
- 3 Slot ECB Backplane
This is a rather bad photo but shows my initial setup in an ABS Rack Case. This is now in a metal EuroCard Rack case (photo pending)
September 2017 Update
Well after a big session I now have my RBC running a custom ROMWBW 2.4.8 with the following hardware. See the forum posts around DISKIO and CVDU for information on what was done there to make it all work.
- CVDU - terminal Video and Keyboard
- DISKIOv3 - 1.44M FDD and Physical HDD
- Z80 @ 10Mhz (see forum post about using Crystals instead of Oscillators)
- Busmonitor
- Prototype card with some basic lights to flash on and off for getting the hang of programming.
The following is the current setup
- 32bit CPU (T4xx/T8xx)
- 4x 10/20Mbit/s serial links for communication to up to 4 other Transputers
- Programmable in Occam, C, Pascal
- Run O/S such as Minix and Helios
What is a TRAM
TRAM's are silly expensive on ebay! So probably not the place to start if you don't have any. Much better to wait for the ECB Transputer CPU Card.
Basic Transputer System
- Host - in this case the ECB based machine
- Host Adapater Card or Transputer link Interface (see ECB Transputer Link Interface below)
- Transputer Network - TRAM Carrier Boards or non-TRAM based CPU Cards (see ECB TRAM Carrier Card and Transputer CPU Card below)
the basic setup is
Have finalised a design
- Supports 4 TRAM's
- cascade to multiple boards
- Power from EuroConnector or external standalone
- Breakout for all unused links
Gerber files for version 0.4 of the board :builderpages:trick-1:4tc2v0.4.zip
Jan/17 - Boards arrived from PCBway, well packed, professionally made and in cool red! Have assembled and tested 1 unit. Some minor layout, screen print and design issues to resolve but they work!
v0.4 plugged into Axel @ Geekdot's Apple II Transputer Link Card
Proof of life. Simple BASIC program using PEEK/POKE to interact and confirm that there is a Transputer connected.
The following is the image of the version 0.4 board with 4 INMOS TRAM's installed.
Jul/17 - Version 0.5 of the board has been finalised and sent for manufacture (http://www.pcbway.com).
Jul/17 - Version 0.5 boards have arrived.
The following files are what have been sent. Please note that this version has had some modifications and re-routing from v0.4 of the board and as yet have not been tested.
- Gerber Files :builderpages:trick-1:4tc2v0.5.zip
ECB Transputer CPU Card (TCPU)
- 1-2x Transputer CPUs on board
- Minimum 1MB SRAM
- head and tail connector
- breakout of unused links
- Power from EuroConnector or external for standalone
ECB Transputer CPU Card -TCPUv0.1
6/7/2017 Have decided that the first development version will be just the Transputer, link connections, power and mandatory support circuit all other pins from the Transputer will be broken out into a header so that I can experiment with memory and other peripherals.
KiCAD and Gerber Files :builderpages:trick-1:ecbtcpu_version_0.1.zip
7/7/2017 Version 0.1 files have been sent to manufacture at (http://www.pcbway.com)…
Jul/17 0.1 boards have arrived….
Sep/17 Version 0.1 board finally built, tested and working!.
errata so far
- Error should have been presented as notError - need to add a 74LS04 inverter to the next version of the board
- Link0 not presented in the uplink header. Link3 is there instead.
- Link Speed Jumpers need to be added
- Tidy up link locations and label
The following shows the current state. You can see the 74LS04 on a vero board behind the main board. Also the brown wire jumper down to the breakout where the link speed connections ended up. Plugged into my IIe running the basic test code and those magic words “32 BIT TRANSPUTER FOUND”
next step is to build out some memory options
ECB Transputer CPU Card -TCPUv0.2
In planning but will be looking to fix the errors of version 0.1 and add the first go at memory.
Also considering adding the bus to link interface circuit so that the board will work standalone in an ECB system but that might wait until version 0.3
Version 0.2 of the TCPU board arrived late December and as usual I got caught up in other things. Building this simple board was been slow progress and was finished in late February. Unfortunately the memory didn't turn up for another month….
Here is the blank board.
Here is the board finally completed and connected to the PC for testing.
Initial tests failed to the CPU, after a while I realised I had tied one of the control lines (Analyze) to ground for some mad reason when I was re-drawing a section of the schematic, out with the knife and some bodging later I was able to see the Transputer. However I could not find any memory. About two months worth of frustration later I have finally managed to identify and talk to the memory, although not reliably or quickly. The issues:
- I had forgotton to connect notMemS0 to the 74F373 enable pin
- I had used a KiCAD 2×10 IDC connector in the schematic that numbers down one side and then up the other, on the board layout I selected one that goes from left to right and down in the numbering…..end result memory timing and configuration jumpers were not where I expected. Took a while to work that out.
The following shows the current test setup
Any how as of late May I am now getting the following which shows that it is at least identifying the memory. However it is not talking to it reliably.
(sorry they are on an angle)
As can be seen lots of errors and lots of different memory sizes for Transputer number 9 which is the one that we are testing. off to read more manuals and recall all that I have lost about T states
The Transputer CPUs (T4xx/T8xx) have a programmable three-cycle memory interface. Through jumper configurations on the board they can support a variety of DRAM and SRAM. More information can be found in the reference manual http://www.transputer.net/ibooks/72-trn-203-02/tdata3rd.pdf .I am now working through the various combinations to determine the best configuration for the memory I am using as the it is not being reliably identified.
I am also yet to get the bank 1 operating. I will do this once I get bank 0 working properly.
So there we have it - some progress.
Next iteration I am going to
- fix the above issues
- remove the ECB bus connector as I have decided a) I need the real estate b) it is a wast of a connector just for power c) power comes through the link interface.
TCPU v0.3 and 0.4
August 2019
So its been a couple of years, work and life have got in the way. Version 0.3 was a total dud….so lets move straight onto v0.4
Per the last update I have removed the ECB connector. I also settled on ZIP memory TC514400AZ's ( https://datasheetspdf.com/pdf-file/1091701/Toshiba/TC514400AZ-60/1 ).
The result is that I now have a Trransputer + 4Mbytes of memory working (happy day!) The 0.4 board is not without issues so needs a bit of TLC. The GND somehow didn't connect to the memory. Also the AD11 on the memory didn't get connected to the bus. Lots of head scratching on that one with various errors. I am also going to move some of the resistors closer to the 74ACT86 and remove some of the jumpers that just aren't needed.
output from ispy | mtest -x
The last line of the last command run is “proof of life”
Now the command doesn't return consistently but I think that is power…to be confirmed. For now thought it is working
This card has been designed but is yet to be manufactured for testing. This is mainly because I have not built enough ECB based Transputer cards to warrant doing so. In theory it is a manual version of the INMOS IMSC004 Cross Bar Switch. Obviously not software configurable.
The card allows the connection of all unused links from other ECB Transputer boards via a single ribbon cable and then allow for the link configuration to be set with jumper cables. This will allow for maximum configuration of a given set of Transputers cards from either Final version of TCPU or 4TC2v0.5 and above.
The following are the KiCAD Design and Gerber Files. I have never had this board fabricated but as you can see it is rather simple.
