I did a lot of hardware debugging before recognizing that all of my available 72-pin SIMMs were not compatible to the KISS68030 board, so I decided to collect information about which ICs work and which do not.
| Samsung KM44C16104AK-6 | Reported working 33Mhz CPU / 64 MHz RAM | |
| Samsung KM44C16104CK-6 | One of the modules was stable at 50 MHz RAM clock, but not at 64 MHz. Not working at all with two modules. | |
| Samsung KM416C4104C | Not working at all | |
| Micron MT4C16M4H9DJ-5 | Stable at 32 MHz CPU / 64 MHz RAM clock | |
| Micron MT4LC16M4H9DJ-5 | ? | mixed reports, 3.3V version of MT4C16, so make sure your module has voltage regulator |
| Micron 4C4M4E8 | reported working | |
| Fujitsu 8117400A-6 | reported working | |
| Motorola MCM417400 | Stable at 32 MHz CPU / 64 MHz RAM clock | |
| NEC D4265405G5-A50-7JD | not working |
If you have a KISS68030 with another brand of memory not listed, I would like to hear from you (same if you know about other memories that are not working).
